Lenj
Hi All,
I have a L'epee clock that I got off Ebay, it was in a pretty bad state, the dial looks liked it had been through a mangle, I kid you not (photo Attached)!! and someone has had a go at trying to tidy up, when I say tidy up, they need not have bothered, covered in tipex or something like it, anyway only fit for the bin.
Question does anyone know where to get a replacement? I have emailed Epee a couple of times and they never have answered. Yes I am looking on Ebay and nothing, people tend to hold on to things like this, I have made a temporary dial out of card and laminated it...It does not look to bad laminated, it will do until I find a replacement..Any help appreciated
Len
Edited by Lenj
Wrong photo will upload shortly
L'Epee is Swiss owned and like most Swiss company's they wont release parts it is more lucrative to offer a full restoration service for your L'Epee clock and charge the earth for it.
I think your only option would be full dial restoration by a specialist  which would probably work out less than L'Epee would want to charge you for one anyway.
The laminated dial looks O.K .
1 hour ago, oldhippy said:
What an absolute mess. The only way is a complete restoration. This place sounds right. It will cost quite a lot.
https://www.clock-dials.co.uk/
Thx Oldhippy for the info, that looks like a great place, just wondering if it worth doing, it looks like someone bent the top of the dial and in doing so cracked all the enamel..It really is worse than it looks..
Len
Hiya, yes I think that they would like to do a full restoration, I have already done the hard part, stripped clean all parts polished by hand, it is working a treat albeit with the laminated dial, I must admit it is very hard to tell the difference once fitted in the clock..Still. L epee could have had the decency to email back.
Len
2 hours ago, oldhippy said:
You cold contact them to find out if they could undertake such a task and a rough cost.
Yes I could do that, may be worth it.. I suppose it will have to be made from scratch, if it's going to be £100 or more would definitely not be worth it..
  • Similar Content
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
