Another clock Quiz
oldhippy
What is wrong with this. It happenes a lot with very old clocks. There is something major.
There are a few bits missing but that is not the quiz.
Is the spring barrel being held together by wire. Very dangerous.
I can see that the back cock ( I think that is the term ) is upside down. I think this would suggest wear on the escapement and the drop on the anchor has had to be adjusted and the only way to do it has been to turn the back cock upside down.
If I'm close then, and the clock has had a major change, it never started life as a anchor escapement  the alterations are crude there are holes in the plate and the back cock is upside down so never belonged to the clock in the first place .
Well its a bracket clock movement do longcase clock pillars and bracket clock pillars correspond in style and date ? if so this clock judging from pillar style would be about 1660 to 1740 because the pillars are "Finned" ?
The clock must be rack striking because there is no evidence of an outside count wheel so that would put the clock to 1680 to 1740, the anchor escapement didnt start appearing in bracket clocks until the 1780's onward, so from date alone I would say the clock was originally a verge that has been converted to a anchor escapement because from 1660 to 1750 the verge was the dominant form of escapement in bracket clocks.
Spot on and well researched.  The conversion is very crude.
The other thing that stood out a mile is the so-called pattern that the back plate has. That has been added at a later date, I expect it was added at the same time that converting it to an anchor escapement happened.
Fusee clocks, Many run by a chain, they also have steel wire, bronze wire or gut. You might think they look dangerous, but they are quite safe.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
