Mainspring question
Hello everyone. I am new to watch repair and am trying to find a mainspring for my beautiful Waltham pocket watch. I looked up the serial number 16253552 and found the following pertenent info.
Grade 161, model 1907, size 0s
With that I ordered a mainspring thinking I had the correct info but it turned out entirely wrong.
Can anyone lead me in the right direction?
Thanks, Terry
Thanks, Terry
Do you have the old one. If so, measure the thickness (strength), height and determine the end type. Also measure the barrel diameter. Go to cousinsuk.com and then search for those parameters. Should be available.
Thanks, Terry
Hi Terry
First upload a good  photo of the movement so we can see it clearly.
I looked up your  movement and got the same information
I'm sure we can get to the bottom of this .
TFitz
Hey Terry,
I have some experience with this as I’ve been working with a Waltham 0 size as well. There are three model numbers of mainspring to choose from. The main difference being the width. You’ll have to measure either the width of the old mainspring or the inside of the barrel wall. Should be either: 1.5mm, 1.7mm, or 2.0mm. Remember when you measure it may not be exact. If you measure the barrel wall, choose the closest one that is the smallest, so you have room for the cap to fit. Otherwise the mainspring will stick out the top. I would recommend alloy. I have found plenty of fine examples on eBay, ofrei if you don’t mind paying a little more.
One last thing. I have had trouble with mainsprings slipping on the Walthams. After doing a little research, it seems you have to put a small bend at the arbor side so it will catch on the hook of the arbor. I have not verified it yet, but there is info out there with a google search.
Here are the model numbers for you:
https://pocketwatchdatabase.com/reference/mainsprings/waltham
Hope that helps get you started.
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
    • Have you got the pallet fork installed in the movement when you see the train move when using the setting works? As nevenbekriev said, without the pallet fork to lock the train, the behaviour you are describing is normal. If this is happening with the pallet fork installed, you have a problem in the gear train, it should be immobile when the pallet fork is locking the escape wheel.  The fit of the circlip above the pinions on that wheel is crooked in your pictures, it should sit flat up against the upper pinion as in Marc’s picture.  Hope that helps, Mark
