Newbie
Hupke
Hi, my name is Marc and I've just signed up due to a question about using a watch winder (or not). I've been watching Mark's youtube posts for some time now and are an absolute fan.
I'm Dutch, work with a British/US company that manufactures marine electronics (mainly leisure) and thermal camera's. I own a few mechanical watches, like an IWC MKXV Flieger and a Hamilton Khaki King DayDate and some Seiko mechanical and kinetic ones. On my wishlist: the IW371446, Portuguese IWC chronograph, lovely watch!
Hope to spend more time on this forum!
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
