Have a Seiko Chrono. New battery installed. Keeps great time and all functions and dials are working but the alarm does not sound. Is there a way to fix this myself? Thank you.
Can you post a good picture of the mov.t. There should be a small spring that goes there, contacting with the caseback.
I have one that I'm working on it as well but just cosmetic stuff. It doesn't have a spring that is visible like a bell-matic, as far as I can see. If I remember correctly the alarm is actually a digital beeping...
Some quartz watches use a piezo piece which needs to contact the caseback via said small spring, that is normally lost when replacing battery.
Mine works and I don't think that it has such a spring...I mentioned that the sound the alarm makes is rather digital... At least that's how I remember it.
That's why I said "some watches", and asked OP to post a picture.
This movement has what looks like two brass tabs that touch the Piezo on the the case back. Make sure these haven't been flattened or are contaminated with something. Also clean piezo on the case back.
Check out the following Image I took when I worked on that 7T32:
7T32_6A50_46.jpg?fit=800,600&ssl=1
The small golden (copper) fork in the center area, in the middle of the two coils, is what they are referring to. This is slightly bent upwards, so when the casebakc is fitted, it will make contack with the piezo-electric disc glued to it. You should be able to see the marks on the disc made by the "fork" on the outer diameter of the disc.
But honestly, I believe the issue is not mechanical (bad contact of the buzzer lead terminal - that's its name). I have hade a few 7t32 and 7t34s withe the same issue, and even if the alarm was working properly, I could only hear an extremely faint "bip" when engaged. This is probably due to the piezo-electric disc. Which btw is not so easy to replace.
It is a beeping sound, indeed. That's why I thought that it's something digital... Can also provide a photo of my movement if needed... Mine functions accordingly as far as I know.
Try a any case back from a another watch with a piezo. Hold against watch make sure there is contact and see if its any louder/works if not....
If it is the Piezo. I used a heat gun on the case back after cleaning old stuff off. Then put piezo Seiko 4589.801 (available from Cousins) on with tweezers glue side down and added some more heat and left it to cool. Refitted and all working.
On some quartz alarm watches there is a piezo piece attached to the inside of the case back. I changed one a while ago to fix this issue but to be honest after the fix I thought it pointless as the alarm sound was hardly audible. I think I purchased the piezo piece from eBay.
Here's a recent photo from me. Hope it helps. The sound that the alarm makes sounds like is a digital beep but I'm guessing it's those little springs that do it.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
