Vigor crystal lift
Lc130
I would say that if you need just this part then just get a new one. The cheap ones will do the job. The claw part I have heard some people to be a bit dissatisfied but I guess it depends on what crystal they were trying to grab...
I have the Vigor vise and have now used it successfully a few times. I bought it in advertised "new old stock" condition, but it may have had a few uses. Still, the jaws were in great shape, which seem to be very important. One thing about the Vigor is that it has a rubber tensioning ring that resides up in the tapered cylinder. Oft times, and in the case of the one I bought, the rubber is stretched, dried, fatigued, etc., so they don't work very well. Without that rubber ring, the jaws just dangle around. I used an O-ring that may be a bit small , but does the trick. I also store it with the vise at near its largest setting, as this relaxes the o-ring so it will probably last longer. If you pull the jaws up inside and leave them there, it probably won't be long before replacement.
IMO, if you buy a used one, make a note of how much use the business end of the jaws show. If you find one in the box, that's probably good too, as the ends of the jaws are protected instead of bouncing off of things in bench drawers, etc. Good luck.
On 3/14/2018 at 12:44 PM, jdm said:
The base is needed to compress.the crystal before reinstalling. If you look on AliX you can find an even better price for the set.
That base actually holds the crystal in place and the metal sides space the compressor up slightly to leave enough plastic at the bottom of the crystal to insert into a case. Am I correct?
Yes, I believe this is correct. I didn't use the base on the first crystal I used the Vigor on. If you have the old crystal, size the jaws until they're just large enough to easily accept the crystal. With the tool jaws up, set the crystal on top. Carefully lift the tool and start closing the jaws, watching how equally they're grabbing the edges.
I found the amount of tension I needed to put on the crystals perimeter very nerve-wracking. I mean I really had to crank down on the tool. it makes one wonder just how much they can take before exploding. Good luck.
    • Got it thank you! I'll steer clear of the lower jewel count movements until my skills are a bit better. I'm literally brand new to this
    • Depends where you are with repairing, watches like you have just mentioned  the Smiths, Ingersolls, Services are often pin pallet watches with low jewel counts, not impossible to fix but often quite difficult due to having more wear than a fairly standard 15 or 17 jewel movement. Saying that you may be lucky and pick one up that was never used much. As an example i spent a few weeks on and off getting the most i could from an old Smiths Empire, that did actually finish at within 2 minutes per week that could be improved further now i know it is fairly precise but not quite accurate . Sekondas are good practice pieces at around a tenner, though some folk call them rough but robust.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
