Need crystal for Casio wave ceptor
Dweib
Help please. Discovered a small scratch approx. 4.5mm long at the 12:00 position on the crystal that I could feel with a finger nail. I tried to remove it with a dremel and felt polishing tip with a dab of polishing compound but only made it worse. So I am now in search of a replacement crystal. Your help with a link is appreciated. Movement is 5110. Watch is WVA-M650D- 1A2JF. I would consider sapphire if it's not unreasonably priced.
Looks like it's a flat crystal, so you can use a generic. I suggest that you bring it to a good watch shop (where they change batteries and do minor repairs) for replacement. They will measure it and if they can't, you can order one yourself for about $1. Sapphire can be around 10 - 15.
Crystal measures 34mm installed. Ordered a watch press set from ebay. Youtube videos show careful removal and replacement looks straight forward. I'd like to do this myself. But need to know where to order the crystal once I remove and measure it.
Thanks I will register with them and order one of their generic flat sapphires after I remove this old one. Not sure of the size yet but I see I can get a 34.1 x 1.0mm sapphire crystal for approx. $27 US plus shipping. Sounds like the plan.
Ordered a 34 x 1 mm flat sapphire from Esslinger. They are fairly close to me right across Lake Michigan. Should have it within the week. Will post again after install.
sent via htc one m9
sent via htc one m9
They already shipped! That was quick within an hour of placing the order. Regardless the damaged crystal is rather inconspicuous now. And you have to hold it at a certain angle to really see it. But I know it's there. So I'll change it.
sent via htc one m9
The sapphire crystal arrived and I must say I'm am not all that impressed with it. It just a flat piece of blah glass. The original mineral glass has a very slight curve to it. So I decided to try rubbing a bit more with that diamond paste. Went by hand using q-tip, paper towel and a few dabs of the heavier 28 micron stuff. It took several hours of hard rubbing but now all the scratches are gone and that depression in the center is just barely felt. Followed up with some finer grades and used .5 micron as a final polish. I'm happy with this and am thinking about not changing the crystal after all.
5dab3b3d2cd723e5dc64c61017ea560d.jpg&key=703740ef61cb805f6fb366858a8424ff4e66b7cd8235a7ed284e2ea14a385ad9
sent via htc one m9
Which is why using a rotary tool on a felt wheel is advisable.
Not if your in-experienced doing so. The reason it took several hours of hard rubbing was not for the original scratch (easily removed several days ago) but for removing the dimples and marks caused by improper use of the rotary tool and felt wheel. I tried the dremel method twice as shown in the esslinger and other videos and both times I apparently applied too much pressure with not enough movement and the friction overheated the wheel on the crystal causing a dimple and tiny score marks. Suggest recommending novices practice the technique on something other than a good watch first.
sent via htc one m9
I think you were spinning the dremel too fast. In fact, these starting at 3,000 rpm are already too fast for polishing, not too mention buffing. A regular drill actually works better.
Quote
It's always good to learn on a throw away watch. Just like paying attention to what one is doing, and not blame others for own's failures.
  • jdm locked this topic
  • jdm unlocked this topic
Agreed. I have an old '70's Timex that's pretty scratched up. I'll see what I can do. But I believe it's an acrylic crystal so I wonder if a rotary tool would be appropriate?
sent via htc one m9
sent via htc one m9
It's very easy to over do and overheat acrylic with a rotary tool. If I'm going to bother polishing plastic, I do it by hand. Mostly I just replace acrylic, I have a good inventory of round crystals and huge piles of various specialized plastic crystals for vintage watches. Then it becomes a matter of digging through the mountain for the right one :-)
Ah.. makes me wonder if the crystal I've been working on above is actually acrylic. Kinda feels like plastic.
I may contact you if the old Timex needs a new one.
sent via htc one m9
No it's not, as mentioned crystal would overheat immediately and be ruined. Isn't even necessary to use diamond paste with these, any fine abrasive compound will work.
Yeah, I love this watch and won't give it up for nothin'. Perfect size, full featured, light weight, solar powered, syncs every night at 12:04, easy to read digital stop watch, secondary time set to Greenwich UTC, 5 alarms, has a light but the lume is bright and easily visible all night long clear to my alarm time of 5:45. WVA-M650D-1A2JF
sent via htc one m9
At this angle you can clearly see the dimple that is still in the crystal. But it's usually not very noticeable. And not seen in the last two pics above. So I won't change it just yet. Dimple was caused by improper use of a dremel and polishing wheel.
Edited by Dweib
I want to know why the devil this $200 watch scratched so easily. I've been wearing a cheap $40 K&S autowind at my machinist job for several months and not get a scratch on it but the moment I wear this Casio for just one day the crystal scratches up?
My bet is that is is not mineral glass, but some sort of hard acrylic. A dremel won't dimple mineral glass that quick. I've polished several old mineral glass crystals (pocket watch size) with a dremel and never made a mark like that, and if it scratches that easily, it also makes me lean towards some sort of acrylic.
I agree with you. That is my opinion as well. Although the specs claim mineral glass.
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
