Hi all,
I've had lots of 7A28's and 7A38's apart before but not had this issue previously - two of the hands just do not seem to bind at all with the sub-dial posts. I can fit them, press them so they are sitting reasonably low to the dial, then just lift them off with tweezers. So far as I can tell nobody has been in this movement before and they seemed ok when I was given the watch. I've only had them off twice so I'm surprised they won't reinstall. I'm sure the 3 sub-hands are all identical but I'll have a good look under the microscope in a minute.  I was wondering if the calendar ring was getting in the way but I don't think it is (sitting nice and central and evenly viewable through each of the 3 sub dial holes, there's nowhere else for it to go).
Any ideas? Is it me mishandling them? I can see from the first pic below that the one on the right is slightly chewed, not bad enough for this though?
Thanks in advance.
Pip.
Pics of top and bottom below and pic of the bottom sub-dial (running seconds) pivot? stem? post? Not actually sure what that bit is properly referred to as.
....you could try some type of hole closing tool. Also a quick non intrusive fix: get a loupe, stretch a thin layer of rodico over the hole with your tweezers. (you will not be able to see the rodico with the naked eye) place over the pivot and seat. This will hold the hand on and work as a temporary fix until more permanent repairs can be made.
The left one looks a little damaged . Pressed them to far down?  Not you but the tinker that was there before?  Or coming from an other watch?  As they don't look the same on the back?
Edited by rogart63
You could give them a squeeze with a pin vice BUT support the inside with something like a piece of brass wire to avoid an oval shape.
Serviced a 7A28 yesterday. Having trouble setting the sub hands in the right position. Not like a normal 6138/39 where you could press the reset button and the hammer holds it in position . Get it right and then press it down it twist a little. And i have to take it off again and again to get it as perfect as i can. That could be a part of the problem? Lots of on and of can wear it out.
I’ve had a bit of on/off with previous services. These have been off once and after I put them on one fell off and one was loose! Might have been someone else’s efforts a long time ago, this was in a drawer for many years (allegedly). It was a complete non runner that I’m fixing up for someone I know. I’m attempting the pin vice later I think.
Apparently the correct technique is to tighten them up in a watchmakers lathe. Someone is showing me the way to do this next week, wish me luck!
I find the best way to tighten hand collets is to use a jewelling press. Works for me every time and is extremely precise.
Edited by rodabod
Like a Seitz? How do you do that?
You use a cup-shaped plunger with a larger inner circumference than the collet. You then lower the plunger onto the collet with light pressure and raise the micrometer gauge back until it meets resistance against the plunger. Now drop the micrometer gauge 5/100 at a time and press until the collet is a snug fit. Where possible, you repeatedly measure the hand collet on a hand gauge to confirm you’ve reached the correct size.
I’ve tried things like using a pin vice in the past, and it can crush the collet out of round and is a bit unpredictable.
You mean, tool ID larger than collet ID (and smaller than collet OD) ?
The plunger ID has to be larger than the collet OD. You have to go through the plungers until you find a snug fit which allows the plunger to just cover the collet.
How can tighten the collet if it's larger?
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
