Hello everyone, I am new here. I have a Tissot Quartz watch from ca. 1980. It has been sitting in a draw for years because the crystal is badly scratched and it is in need of a good clean.
I would like to replace the crystal myself and have removed the back; crown and what seemed like two retaining screws for the movement. However the movement refuses to come out although it rotates in the housing. On having a closer look it seems to be locked in place. Could anyone tell me if this is a locking ring and if so how do I remove it? If not do I have to remove the movement from the front. Any advice would be greatly appreciated.
Thank You!
Can you post a front and side pics, as it's quite possible that mov.t is removed from there. Also, try a battery in it first, because if it doesn't run you'll need to re-evaluate your options.
A lot of movements are removed within the case ring. Try refitting the screws and giving it a good tap on the crystal. It may be dirt or rust holding the movement in. If the crystal acrylic it might be a front loader ?
Sent from my SM-T585 using Tapatalk
DSCN0542.thumb.JPG.c496809236f9d57202643d5f8ff875be.JPGDSCN0541.thumb.JPG.e4747e0fd6d2093c502e4746926de876.JPGDSCN0546.thumb.JPG.60e481c746d62cfa92fd1448e72cf2a1.JPG
Hello again, Thanks for the feedback.
Here is a front and side picture. As I mentioned before the movement rotates inside the case and that why the display is 180° to where it should be.
I will try putting the screws back in and give it a few taps to see if that helps although it seems to be locked in place from the back. The diameter of the movement seems about about 0,5 mm bigger than the hole in the housing.
 That comes out from the front. There is a crystal ring that is held in with a gasket. With the crystal in. You won'ty have any luck tapping on the movement ring as that is a part of the case.
That's not a front loader. Still think the movement comes out with the ring. See pics of similar, on my Vostok that I've just replaced the mainspring 47b447ec1da7bed48a5510cad71f4dc1.jpg38dd07a36e335113246a59b5e18803a7.jpg
Second thoughts it could come out the front. If you can't dislodge it. Remove the bezel . Then gasket and crystal. Let us know. I still think it's dirt holding it in ?
Look around the perimeter of the bezel ring where the crystal fits. Does this ring appear to be separate from the rest of the case? Are there any slight “lips” where a case knife can be inserted?
Thanks everyone for the advice, I can't see it coming out the back unless it's a removable ring thats holding it, but  the ring seems to be part of the case. I will have a close look at the bezel on the front and get back.
I think I spy two small holes in that ring around the back of the movement.
Sorry this is a poor markup, but I’ve drawn 2 rough circles where I think I see the holes. So does this ring work like a circlip? If you put 2 pins in the holes can you squeeze them together to compress the ring?
One can also avoid removing the bezel or mov.t. Just close it replacing back and crown gaskets, then polish out the scratches (that's a bit of a messy work) as described in various threads here, use search function on the top right. Although it seems to have a flat crystal which cost about $1, then a press is needed to fit it back, and few more tools for a proper work.
Hello Stuart, That looks promising with the two “circlip holes”. Well spotted  :) I will have a close look when I get home and report.
If I can’t get the movement out I will try polishing out the scratches as suggested by jdm
Hi Guys, Thanks for all the advice. It came out from the front after all. I just had to find the correct place to insert the knife.  I will have a look if I can repair the scratches in the crystal before I press it out. They are quite deep though so now that I'm this far I think I would like to replace it.  Also I would like to give the case a good clean and remove the scratches.
Quote
removing the front bezel is not always easy,  but it must be removed on many wrist watches.  on a "first time job",  buy a special tool.  vin
You could probably fit a generic crystal instead of the original . With a new plastic gasket. Take care not to break the crystal when reinstall the combo. Been there done that as they say :)
1 hour ago, digginstony said:
Never would of took that to be a frontloader.
If you look at the pics, the dial is slightly bigger than the back opening. I didn't do forensics pixel counting, but you get the idea :)
The ring (circlip or not) which the OP correctly identified to overlap the mov.t is meant to keep it firmly sandwiched even with caseback removed for battery changes.
If you look at the pics, the dial is slightly bigger than the back opening. I didn't do forensics pixel counting, but you get the idea [emoji4]
The ring (circlip or not) which the OP correctly identified to overlap the mov.t is meant to keep the it firmly sandwiched even with caseback removed for battery changes.
Interesting but I thought the movement was screwed into the ring and if they came out together and that's why I didn't bear relevance to the overlap [emoji16]
Sent from my SM-G920F using Tapatalk
Well done. The answer is always there if you stare hard enough at the parts!
Interesting to know what those holes were and their purpose. It was a good observation and a circlip fixing, a very sound idea.
Also a sprung circlip could aid shock protection to the movement.
I never come across a movement so fixed but hopefully there's always time [emoji16]
Thanks,   I have now cleaned the case and it's looking good. Been working on the crystal and have managed to get all the scratches out but having trouble getting back to a polished finish at the moment. I have really enjoyed the project though.
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
