This Armani chronograph has just come in, the winding stem & crown having been ripped out ! post-31-0-10386400-1409866474_thumb.jpg
The movement is a seiko VD53B, post-31-0-10386400-1409866474_thumb.jpg I've managed to identify the stem from cousins parts list as ; 0351-177 but can't find any reference to the crown and as it is missing, don't know which one to order ?,
also as the stem has been ripped out is it likely to have caused any internal damage to the watch ?,  any advise would be greatly received.
Many thanks   Phil.
Hi Phil,
Here are the specs for the movement: vd53_tech_guide.pdf
Alternatively you can just swap it for the same one which is only about US$25. They come brand new with battery and stem that you will have to fit: http://www.esslinger.com/hattori-japan-vd53-quartz-watch-movement.aspx
As for the crown, you might want to either try with a distributor but it will be expensive or get a generic by estimation of the size. Here is what it might look like:
I hope it helps!
For cheaper quartz movement (I know that "cheap" is relative), I would just replace the whole movement with a new one. And use the old one as a practice movement and spare parts.
I'd go with that advice as well. Seiko quartz movements are comparatively cheap to source.
It makes sense to just change the movement as they are so cheap - at least then you can offer a sure guarantee to the customer.
As for the crown - if you cant get an original you will need to measure the pendant tube and estimate the original outside diameter of the old crown then determine the thread of the stem and order an aftermarket with those dimensions.
If there is a case number you could try to source an original - not sure if Armani has a service/parts department. These guys sell the straps - maybe they can help with a crown? http://watchpart.co.uk/emporio-armani-c-451_65_121.html
you'll get an original crown from Ian at Jevon & Stanley I'd have thought. he's got me several genuine Armani parts that I didn't expect.
Edited by Lee
Thank you Lee, I'll give them a try !
Phil.
Lee that's valuable information, last quote I got from esslinger was worst than buying a new watch...just a crown! Thank you for sharing!
Just a quick update,
unable to get a genuine crown I took some measurements from the case, luckily there was a slight machined recess in the case where the crown sat so it gave me the diameter,
I ordered a generic grown & a genuine stem, when they arrived I cut & trimmed the stem to length and were pleased with the results  post-31-0-57979800-1410811250_thumb.jpg
A quick clean up, job done I thought !
then I went to press the back on and the glass broke !!   :(
The back was very hard to get off but I used the proper tool & it left no marks,
I've taken off the front bezel & glass and as the movement and dial come out through the front have removed it to avoid any further damage.
I've tried pressing the back onto the empty case but at the moment is refusing to go on !, I'm just having a pause for thought while waiting for the new crystal to arrive. :cigar:
Phil, sorry about your crystal, normally, when I have to use the press to close a watch I select the dice that will not touch the crystal, i.e. one with a well that only supports the bezel/body of the watch and a flat one as appropriate for the acutal back. This will avoid pressure on the crystal itself. Too big may be as bad as too small a die. So far I think you did a beautiful job!
By the way, the plastic ring that holds the crystal should be changed too since the old one may already be compressed to an unusable estate. Hope this helps.
Thanks for  your input & advice Bob,
I'll post my results,
best regards, Phil.  :)
After repeated attempts with my press the back of this watch just would NOT go on ! , I could see the centre of the nylon die flexing a bit like a diaphragm & being quite large (45mm) it was just absorbing the force.
I eventually used a small engineering clamp, it looked a bit Heath-Robinson but the back clicked into place easily on the first attempt. :woohoo-jumping-smiley-emoticon:
New crystal fitted, cleaned up, reassembled, etc, very pleased !.
Many thanks to all for your replies & advice,
best regards,   Phil.
Well done Phil, I like a bit of lateral thinking.
Thanks Geo !
I might have a crack at that if my silicon grease doesn't help...
Hope it works for you Will.  :)
  • 4 years later...
Hi just come  across this site, was interesting to read comments, Am unfortunately in same  situation  crown come off and lost it, now looking  to buy crown and stem for Armani Tazio watch, model number,AR6088.Any help from anyone be most appreciated, Thanks Gary
If you read above there are names of parts suppliers.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
