This is Elgin 18 from the late 19th century.  I really like the watch, but it needs a lot - hands, balance staff, hairspring and crystal.
Anyway, I just could not get the bezel to unscrew, impossible to get a grip.  I found a video by tshackantiques on how to remove bezels (or backs) using a hot glue gun.  I couldn't believe how well it worked!    Run a bead of hot glue carefully around the bezel.  The heat expands the bezel which helps.  Stick the lid from an appropriately sized jar to the bezel.   While the glue is still in a plastic state, it has a lot of holding power and the grip the lid gives makes it a piece of cake to unscrew the bezel.  When cool, it does not stick to the metal and picks off very easily.
  • Like 5
Good tip! Reminds me of the trick using superglue and a large diameter nut to remove casebacks. Worked a treat for me. (Nail polish remover to get rid of the superglue afterwards).
    • Thanks for the answers. In my case space is very limited: I only have the kitchen table on evenings. This is why I am considering a mostly water-based system (keeping heptane only for balance complete and pallets) and no cabinets, no big machines. Any advice for water-based detergents that I could procure from Sweden (ordering from Cousins is OK especially for non-hazardous liquids because normal shipping would be used). Should I really get an ultrasonic for those or would it also work by hand? Thanks!
    • I'm glad it worked out well for you. Must feel good to learn some new watchmaking black magic huh? 😂 Can you post a photo of the crown after all this, I'm a bit interested in how it looks compare to how yellow it was before, never thought alum could dissolve oxidation as well, maybe I can work out the chemistry behind it, something to do with the electrochemistry list, but I'm too lazy for it so 😂 you are lucky it was only yellow, the layer must be so thin it didn/t damage the finishing enough to be noticeable.
    • Thank you Andy, I will keep that in mind.  Fortunately this time, I tried to drill the stem out before finding out about the alum method, therefore most of the stem was hollowed out.  When I took the crown out of the third bath, I was able to screw the whole replacement stem in.  It us now in the ultrasonic cleaner to get any remaining gunk out. claudio
    • I haven't been on the forum for a while 🙃 A family member had a 955.112 watch running with an intermittent fault. Bought a NOS 955.112 movement, but to be sure, I'll give it a full service. It has been a long time since I did the 955.112, so I went back to @VWatchie walk-through ........ Again, I'm struck by the quality of it ❣️ Superb work 👏 🫶 🙏
    • Hi Neven , Agree we you that guard pin is in general a suspect , but OP replaced the fork, no joy.  Perhaps roller is damaged or misses the guard pin, so OP is going to check the escapement with high magnification &  adjust end shakes as well. Regs
