Hard to spot wear/damage.
Reassembling an FHF 96-4 movement, I was gratified (in the usual self-satisfied way!) when the balance went in and it started up. However, it would only run dial side up, and as soon as I turned the watch over, it stopped. It took a while to fathom it out, but I closely inspected the balance pivots and discovered the lower one was worn. This was the best photo of several that I took and it is not very easy to discern the wear on the pivot. It is the left-hand one in the picture. For me it is a reminder to carefully examine these type of components as I am disassembling the watch. Hope this is of interest to others. Luckily, I have a balance wheel from another movement, and that has cured the problem.
Edited by fjseal
Last sentence added.
For more detailed pictures just place the eyeglass on camera or phone lens. Works very good.
On 12/8/2017 at 4:04 PM, oldhippy said:
It is good practise always closely examine every part. Try to remember this with every repair, it will soon come naturally.
To add on Oldhippy's excellet advice... you need to inspect each parts function as you dismantle the watch. ..
As an example...when removing the crown, check if the crown works as it should. Also set the hands to see if all is ok and that the cannon pinion has proper friction. If you skip this step you may find that when you refit the cannon pinion needs tightening or the watch doesn't set because the setting (keyless) mechanism is worn.
I have kicked myself a few times over stuff I should've caught earlier... usually its due to overconfidence. Sometimes it may be because you already think you have identified the problem but there may still be others. I have several watches in my stash from which I have robbed parts,  one Tissot 781 has sacrificed its barrel, balance and centre seconds pinion. The scavanged parts have been replaced by the faulty one because I felt it would be handy to have something to compare with if I need to rebuild this movement. The next guy to work on this (when I'm gone) will probably catch the barrel and balance but he may only notice the faulty seconds pinion only after the watch is fully assembled.
Anilv
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
    • You can try a rubber on that the sort for rubbing out a pencil.
