Certina 23-20 balance
rogart63
Trouble finding 23-20 balance or hairspring . Have a good balance but the hairspring is a tangled  up pretty bad.  I talked it over with friend and he says they are rare . I thought i could take an othe balance from a 3´23-30 but they are shorther and 19800 freguency.
Cousins stock a complete balance.
The balance on cousinsuk cost £80 plus shipping. Not sure the owner wants to fork out that kind of money? Have looked on Ebay but all i can find is 23-30 movements . Not any 23-20 . There is a seller that has a 23-20 balance . At least that is what the selling says . But on the package it says 23-30 . We have contacted him but haven't got an answer yet.
Guys, I think 80 pounds spare part for a brand vintage watch is little money!
People (2 hungry adults) eats out for more! Gets the house fully cleaned for more! Buys horrific fashion quarts watches for 3 times more!
If you repair for yourself, good to save as much as possible to preserve overall funds. But if it is for another person (friend or not)... their choice, no need to stretch to save little money, as they won't have it fixed any cheaper, anywhere else.
    • I went with 8.90£ because 12th century Italian mathematicians are always excellent topics to bring up when trying to get your guests to go home.
    • As a beginner, I’ve found this forum invaluable. I doubt I would’ve persevered without its support. I’ve had the confidence to attempt things that seemed to me impossible only because I knew there were patient and giving folks gathered around this watering hole, available to share their skill.    I would very much like to know where to go if this one dries up and everyone needs to decamp.  There’s something special about the folks gathered in this group.  How to keep in touch?
    • After a 3-week work fiasco that took up 137% of my time, I was finally able to get back to restoring a G. Boley 8mm lathe I picked up on eBay. I still need to do a bit of polishing on the tailstock but it works very nicely. Before and after pictures below. In any case, when I was reassembling the motor I wasn't quite sure which side the pully attached to, or if it matters. My question is ... does it matter? The listing photo below shows it the reverse of how I have it now, but it seemed that the cord and the reversing lever(s) should be on the right away from the belt.
    • Thanks Richard.  That’s clear.   So - another question - how much latitude is there in barrel and spring sizing? Say I have have measured the ID of my barrel to be 9mm and (all other mainspring specs being equal), the closest match I can find for a replacement mainspring is listed with an 8.5mm barrel size, is it acceptable to fit the smaller spring in to the slightly larger barrel without compromising anything functionally?  I’m in this situation now with an AS 1686 which has a 9mm barrel, but the closest replacement I can find has an 8.5mm diameter listed in its specs.  I can find an alternative 9mm spring, but would have to accept a different thickness.  I’m unsure how much wriggle room is acceptable, or whether in mainspring sizing, there’s a priority - ie thickness over barrel size etc. Thanks again for any info.  Cheers, John
    • We already have a Facebook group run by Mark , so this is a bit moot. Search for “Watch repair lessons” group.   Tom
