Another Buzzing Accutron - Thanks Geo!
Lee
After Geo started the time to hum topichttp://www.watchrepairtalk.com/topic/426-time-to-hum-again/?hl=accutron#entry2872 I had to have one!
I brought this little number yesterday & it arrived this morning.
these are a really pleasing watch, prices are VERY reasonable & there's loads of history available about them online & the buzz from the tuning folk is lovely to listen to. I'm amazed these aren't dearer to buy.
Anyway mines a 1969 (year I was born) Accutron  spaceview,  with the Swiss 770 case, wide gray chapter rings & orange second hand. the wider chapter ring & orange second hand tie in with it being a later 1969 as they changed these details due to falling sales against the increasingly popular 218 models. also my case back is missing the mention of water resistance which was taken off later in the 1969 year so its quite easy to date.
Lee
ive put batteries in them over the years but never seen a spaceview until Geos topic. I just liked the look of it & when I realised how reasonable the prices are I kept my eye open. I also have a thing about being left handed & crowns, it bugs me that watches are rarely available as a leftie. so this fits the bill as the adjustments made from the case back, that I like! its a watch that ticks a lot of boxes for me!
Hi Lee, that's a really nice looking example that you have managed to acquire. I'm glad that posting a picture has ended up with you getting one. Enjoy!
That's me just back from holiday and I had my Omega hummer with me for a change. A word of warning though, if you leave it on a bedside cabinet that is empty, the cabinet acts as a sound board and you will end up with an amplified 300 htz keeping you off your sleep. It took a while before I worked out where the noise was coming from!
in the first couple of days this watch was gaining a minute a day, so I brought an Accucell-1 from the small battery company. These are nicely made, they have a resistor packed in somehow to reduce the voltage. It broke my heart having to pay £7.80 for a single battery! but its now keeping time to the second!
Hi,
  I just read this question about taking the accucell apart. I have done that and it will work for several battery changes. You have to be careful in that there are two copper plates inside the plastic ring and they are attached to the battery with what appears to be hot melt glue. You do not want to damage the small diode that is between the plates. You will need to remove these plates from the battery then reinstall them inside the spacer ring along with new battery. The new battery should hold the plates in place inside spacer without using any glue. I have managed to reuse them 3-4 times before they failed. The good thing about trying this is the battery will be dead when you start to work on it so you have nothing to lose. One other thing you will need to watch out for is that the battery is not too thick when you finish. Make sure you use proper battery and everything seats properly, otherwise it could be thick and damage the plastic plates of the movement.
Charles K
Have you tried taking an old accucell apart for a battery change? or brought a new one each time?
I must have missed this.
I have not tried to re-use the accucell case, but having just read Charles' post, I'll probably give it a go.
Thanks for the detailed explanation Charles!
Just a few observations and please pardon me if its stuff you already know.
I have a few Accucell-1 batteries and when I started messing around with Accutrons the main thing I had my attention drawn to was the battery choices and Voltage which is 1.35 as opposed to the Renata 387 which is 1.55.  There is a handy table on another site:
Model Mercury type Silver Oxide type 214 387 387S, 394**, SR936SW** Accucell 1 218 343 344, 350. SR1136SW Accucell 1 219 343 344, 350, SR1136SW Accucell 1 2210 388 329, SR731SW*** Accucell 2 230 343 344, 350. SR1136SW Accucell 1 224 343 344, SR1136SW Accucell 1 ESA 9162/4 343 344, 350, SR1136SW ESA 9210 343 344, 350, SR1136SW Omega 1220 343 344, SR1136SW Omega 1300 313 357, SR44 Omega 1301, 1302 343 344, 350, SR1136SW
***Not a perfect fit, but there is no direct equivalent to the 388.
** These are not supplied with the little plastic spacer. Re-use the spacer from your old 387 mercury cell.
You note that for the 218 they advocate use of Accucell and also the 344/SR1136S but the main difference between the batteries is the Voltage ie 1.35 as opposed to 1.55. The use of either battery on a 218 is possible (if not recommended) but if the watch is normally phased for 1.35 and if you then use a 1.55 then it can lead to double indexing on the index wheel.  Some repairers re-phase the 218 to use standard Renata 1.55 cells.  I suppose what I am saying is replace like for like as if it has been re phased and you put an accucell in then it could lead to a problem.  I have a few movements that are humming nicely but even though they are only movements without cases I always check them out with an accucell.
The 214 has a similar sort of choice, if you buy a Renata, the 387 is shown on the package and it has the black plastic spacer disk on it but the positive side of the battery shows the number 394 and it is 1.55v.
I have just returned my Accutron (bought in May) to the dealer I bought it off because gold on the case and crown was literally rubbing off.  It looked great when I got it but it had obviously been brush plated to give it a thin gold coat.  Give the guy his due and the benefit of the doubt he appeared quite surprised when he wrote back to me after inspecting it and agreed that it was not acceptable.  He offered to source a replacement case which he sent pictures of and I have accepted.  It makes a nice change to get customer service - I had expected a bit of a struggle.
Anyway its nice to see the hummers getting a bit of attention.  Lee put me on to the Stereo Microscope which has made a great difference for examination of the index wheels.  They are not easy watches but definitely have less bits inside that the Mechanical ones :D
Cheers,
Vic
These books(pdf) are very informatives. I have them and I have one but my watch need some repairs...there's no 'hums ' enve if i put a battery in it..anyway, I keep it :D
Battery Selection Table
Hope this is better.
Cheers,
Vic
Edited by Vich
Lee that is a super-looking watch and the strap is sharp too! Besides Omega, Bulova is one maker that I keep close to me because I love their history and designs. My Omega Constellation f300Hz chronometer (198.0022) uses energizer 344/350 with no problempost-328-0-08866900-1415163273_thumb.jpg
But this is a different movement than the 2xx series by Bulova and was modified under license by Omega. A few other watch companies used this hummer topower in their watches too such as Zenith, IWC, Movado, Longines, and I think Certina. They all used a variant of the ESA movement 9162 which is basiclaly what is inside my watch--a Omega 1250 caliber. I have a watch that  takes the best of both companies. By the way, I had my watch serviced here in New York by Ernie Goldman of StarFindings (its on the web) down on Canal St. and he only does Accutrons and is a graduate of the Bulova Schook etc., etc. He told me a lot of baloney all the time about batteries and stripped index wheels and such and not to believe it because this movement is actually very robust. I mentioned this because Ernie is a very forthcoming person and he's been in the business a long time![attachment I do agree with Vichy when he says replace like for like and don't just go and buy the accucell replacement. My watch runs as good as any watch in my collection--In fact I use it as a reference to set the others.
JC
Here it is again showing off
Getting back to your watch Lee...that is beau--ti---ful....wear it well buddy!
Edited by noirrac1j
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
