This Makes me mad
Tmuir
I know RAF sector clocks have recently become 'The in thing' and cheap reproduction quartz sector clocks are popping up everywhere which I don't have an issue with, but I do when an older clock is fitted with a new dial just to make a few extra pounds it annoys me. Atleast they do say it is a repainted dial in the title although no mention in the description.
https://www.ebay.co.uk/itm/R-A-F-FUSEE-SECTOR-CLOCK-FULLY-SERVICED-AND-REGULATED-REPAINTED-DIAL/312008961077?hash=item48a52eec35:g:ELMAAOSwNchZ-hHq
This one does state it is fitted with a new dial 'similar' to what was fitted originally to make it seem more like it was a real sector clock
https://www.ebay.co.uk/itm/CHAIN-DRIVEN-FUSEE-RAF-STYLE-SECTOR-DIAL-CLOCK/112631887006?hash=item1a3962349e:g:I3cAAOSwH2VaAL-o
I'm guessing it wont be long before more spring up and are attempted to be sold as original, or in 20 years time when the paint has warn a bit on these ones being sold as real sector clocks.
  • Confused 1
I've seen two of these recently in Yorkshire England one in a antiques centre in Hebden bridge and one in a antiques centre in Wakefield I certainly don't think there is anything old or original about the clocks at all and suspect they are coming from India they are however easy to spot and are always far cheaper than a true unmolested Elliott original which would be £2,000 -- £3.000 at auction.
Both those clocks have been listed then relisted on Ebay numerous times.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
