Massimo Posted November 19, 2017 Share Posted November 19, 2017 Hi all, I'm trying to remove this movement from the case to clean and buff it, but the movement seems stuck. It turns around 20 degrees and stops. Any suggestions? Thanks! Link to comment Share on other sites More sharing options...
rogart63 Posted November 19, 2017 Share Posted November 19, 2017 That is probably the gasket around the movement that is holding the movement in place. The black one . Remove that and the movement will come out. Could be hard as bakelite so could be destroyed when taking it out but there is no other way. 1 Link to comment Share on other sites More sharing options...
oldhippy Posted November 19, 2017 Share Posted November 19, 2017 Sometimes you have to dig the little bleeders out. Link to comment Share on other sites More sharing options...
ro63rto Posted November 20, 2017 Share Posted November 20, 2017 With this type of case, it pushes out so you need to push down on the crystal with the palm of your hand. Link to comment Share on other sites More sharing options...
jdm Posted November 22, 2017 Share Posted November 22, 2017 Why is that old basic Seiko mov.t look so much better than current ones? Link to comment Share on other sites More sharing options...
Massimo Posted November 23, 2017 Author Share Posted November 23, 2017 Done! Thanks guys!I already have the crystal but looks like I should find the 2 gaskets too... Link to comment Share on other sites More sharing options...
