Hi from Singapore!
trident
52 minutes ago, trident said:
Hi,
I am from Sinagpore. Was into watch collecting but took up a watch repair course a few months ago. Have been practicing with some old watches. And I hope to learn from all the experts here.
Welcome onboard! The more u practices the better u will be.
Hi friend, My Grandson  collects watches. I learnt a little many years ago from a swiss trained watchmaker and have recently taken it up again to pass the time with interest. I have had one failure which I am now getting on top of as it had been botched up years ago by a cowboy who got it going to sell it !.  Interesting !!. The more we practice the better we get. Amateurs are not liked a lot over here very much by the watch making fraternity but there are not many "pro`s" left now. I had a Chinese watch here last week for a new crystal. Clone ETA. Very good it was as well. Good wishes and best regards,  Mike. PS. Have you got a copy of Practical Watch Repairing ? I use it often for reference and Mark Lovick on U Tube who runs courses is an excellent watch repairer.  I am bit old for his courses almost 76 now. I also have purchased a Timegrapher 1900 (£147) GBPS. and worth every penny. Good wishes, Mike.
Thanks Mike for the warm Welcome. And yes I do hv a copy of Practical Watch Repairing and a timegrapher too. I have just cleaned and oiled a Russian Slava 2428. The date wheel mechanism is a bit tricky though.  Hoping to complete it today or tmr.
On 11/13/2017 at 4:04 AM, trident said:
Hi,
Well done trident, you are doing OK.  Good luck with the Slava 2428. You will fix it just take your time. I  cleaned an old friends  manual wind Avia yesterday,  Then a tiny touch of oil on pivots etc.  The balance is worn but it keeps reasonable time now. He is very pleased and one can easily make a rod for ones back trying to get an old watch perfect on the Timegrapher. If these old wrist watches keep reasonable time dial up and crown facing down then I am satisfied. Mark Lovick would do better but I will never have his skill, he is excellent at this business. The best that I have ever seen. Good wishes friend.  PS. I do not use specialist cleaning fluids. Just Benzene and usually Naphtha with a U/S cleaner,  for oil I use Pegasus or Anchor. I find these materials to be fine. Best regards, Mike.
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
