Looking To Invest In A Timing Machine
Hi all,
I am looking to invest in a good timing machine and have been looking at the
TYMC range on Cousins and have especially been looking at the 5000A, has anyone had any experience with this machine. I am also looking at the more cheaper Chinese option are these reliable..
Any help with this will be greatly appreciated Guys
Many Thanks in advance
Darren
I use the exact same machine. I recently rebuilt a Tag chronograph that came to me in parts out of the case. Did not run and when I got it cleaned and back together was badly out of adjustment. By putting on the machine I was able to quickly get it in beat and regulate the time to within seconds a day. I would not be without it.
Charles K
I got mine from AceTimer.  They are American based, and the text on the machine is in English; instead of Chinese.  Also the power adaptor is rated for 110 ~ 240V so it works with any voltage, anywhere in the world.
Anthony Chau from AceTimer matched the prices of the ones from Hong Kong, and even followed up with an email to make sure it arrived safely and was working well ... outstanding customer service!!
Here's the website mate:  http://www.acetimer.com/Timing-Machine/
Anthony's email is: [email protected]
Extremely happy with my purchase.
Many Thanks CKELLY and Lawson for the advice it is greatly appreciated,my apologies for the late replies (Internet connection problems) I am going to have another look at these machines as it seems a lot of people are using them,has anyone had any experience with the TYMC range
that Cousins has on their site...
Thanks and best wishes
Darren
Many Thanks mwilkes and bob
after viewing the video and all of the feedback from you guys, looks like i may punt for the 1000 but I will also check the 1200 as well bob...
Many Thanks to you all for your help with this
Best Wishes
Darren
Hi Guys
Just one more question...
It maybe a bit of a stupid question but is the "Lift Angle" to align the movement for accurate amplitude achieved by moving the microphone stand up or down and keeping an eye on the screen, have I got that right..
Many thanks for all your help
Best wishes
Darren
Hi,
   Another thing you can do is just search the internet for lift angles for whatever caliber movement you are concerned with. I have downloaded several sheets with lots of different watches and calibers. On the Chinese machines they will automatically tell you if you are in beat or not and how far off you may be. They will also automatically tell you how fast or slow your watch may be. Once you plug in the lift angle it will tell you the amplitude of the watch. The one I have defaults to an angle of 52 but you can manually set others.
Charles K
As CKelly says, there are charts on the internet that lists the lift angle for different movements. The most popular are 52 and 53 degrees but there are many variations. I will definitely find out for the movement you are working on when you test it. Hope this helps.
Many Thanks Bob
Much appreciated, I have now taken the plunge and bought a Timegrapher 1900 and am now looking forward to receiving it, Many Thanks for all your help Guys...
Best Wishes
Darren
Hi, I,m thinking of the same unit.... is the price difference from the Timegrapher 1000, to the 1900 worth it?
how are you getting on with it?
Thanks
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
