Help on an ETA 2391
Delgetti
Hello,
does anybody here know the ETA 2391 or a similar movement? I have to reassemble this one and I have to admit that I don't really understand how the time setting works. :wacko:
I only know the standard design on other movements with a cannon pinion. When you set time, the cannon pinion slides over the minute tube.
But on this ETA 2391 there is no seperate cannon pinion, it seems to be fixed to the minute wheel. But how does time setting work with this? Which part can do the sliding? Thanks for any help.
It's a standard for the eta movements, the wheel that sits under the cannon pinion has (in this case) 3 arms that provide pressure for the hands to run, and let the cannon pinion slip for hand setting.
The drive of the movement comes through the 4th wheel pinion (7 o'clock on the picture shown) directly to the wheel under the cannon pinion.
I don't recommend dismantling the wheel, unless you have a spare, as the tension is critical to keep the watch running.
Tom
9 hours ago, Delgetti said:
@FlyingWatchmaker: Thanks a lot. So the cannon pinion isn't totally fixed to the wheel, but can rotate against it. I couldn't spot that on my watch. Maybe a little amount of grease is needed here as the part was cleaned?
I will try reassembly during the next few days and give a feedback here.
Very very little grease. Some say no oil or grease  but i use HP1300 . I check that it's tight by slightly trying to rotate the inner part. You get a fell for it when you service a few of them.
Ok, I reassembled the keyless works and the wheels for time setting yesterday evening and it works. B)
Thanks to FlyingWatchmakers advice I knew where to look. Here is a pic of the downside of the minute wheel. Easy to spot the 3 mentioned areas which work as springs. I put a very little amount of 9501 in this area and blocked the minute wheel to test. Time setting works with a good feeling of some friction.
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
