I'm thinking about getting one of these. Has anyone used one of these and do they actually work ?
It looks bulky and how do do keep leverage on the watch case5b7677ffed2ecdbbd8ca91bb44347775.jpg
How can this work? It may help in grabbing the bezel, but the strength of a normal man is not enough anyway to pull it out. Unless we're talking about $10 Chinese watches.
That what I was thinking.
I'm thinking that that gap might allow, in some cases, using a knife, as well, to pry open the bezel.
I've wondered about how good this tool is as I was thinking about getting one as well.
I have a bezel remover see pic but to be honest I don,t like it. The best way I have found to remove a bezel is with a old butter knife. It has a nice thin blade but is flexible so no damage to the bezel or case.
59b252bea784e_ScreenShot2017-09-08at09_19_57.png.f438df8e98e63f7a7000dfd1c0adfcec.png
Trusty butter knife/bezel remover
59b25350bc29b_ScreenShot2017-09-08at09_22_27.png.4eb31934d3dcb574bd4dda74bd6855a4.png
50 minutes ago, clockboy said:
The best way I have found to remove a bezel is with a old butter knife. It has a nice thin blade but is flexible so no damage to the bezel or case. Trusty butter knife/bezel remover
Try that on a Seiko Sumo, or even a 007 and you'll have it bent or in two parts. A flexible blade may not damage the case but it's also ineffective. Hard bezels are removed with a Seiko S-28x knife opener, (or a good copy), and the tip may need further sharpening. The large handle allows to pry correctly, remember that damage is done when twisting, but when you pull the tool handle up, the tip pushes on the case which is covered by the bezel, and the lower edge of the bezel, leaving no marks.
I have used my butter knife method with Seiko divers, and also used it with my Rolex and Citizen bezels with no problems. Perhaps the Sumo is a different stye of bezel.
It's the same style, but much harder and inaccessible on the sides. If you could have a video removing an SKX007 bezel with a butter knife and no twisting, I'd love to see it.
Next time I get a diver or watch with a  bezel I will do. Watch this space !!!!
But not an Invicta, sometimes they can be absolute "Bleeps" [emoji16][emoji16][emoji16]
Please try on a Seiko 007/9, which is the specific watch I was referring to. I agree that other types may be much easier to remove with improvised tools.
Ok I had a spare hour this afternoon so I thought I would have a go removing my Urchin bezel using a knife.
After about 20 minutes using a whole selection of kitchen knives and being totally red faced I hadn't made any progress (The Mrs won't be happy with me when she gets home from work and sees the knives either) I even taped the lugs and tried leverage and twisting, still no joy, so I gave up.
So I got the Horotec case grab out and removed the bezel in a couple of minutes. I don't reckon this tool to much as a case back remover but as a bezel remover, it's the BEST I've come across.
So insert the jaws apply tension, the bezel pops and gently lift up with no effort with a Seiko type case back remover. See pics e606e40bfd5a240ef5adaa134fe4ee8f.jpgea103fb03c65903b9d118e44c5065d79.jpg03b29f2631fc9b0e12ab4c11aa0df30d.jpg
That's heavy machinery! I have a Sumo which will need the bezel removed, and I would be much more relaxed with it. Will look on AliX for a knock-off :biggrin:
That's heavy machinery! I have a Sumo which will need the bezel removed, and I would be much more relaxed with it. Will look on AliX for a knock-off [emoji3]
From what you've said, this sort of tool could be ideal for a Sumo. I haven't been tinkering with wrist watches for that long, normally I play about with pocket watches but over the last year or so have certainly fallen for Seikos. This tool has been perfect for my skx,turtle and urchin.
As for using a knife, if there is a knack to it I certainly haven't got it. [emoji30]
Sent from my SM-T585 using Tapatalk
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
    • Thanks for the reply. I polished the head of the screw using 1500 to 10000 lapping paper and a screw polisher. This is why I think the head blued and the rest of the screw didn't. Silly question, how do you polish the whole screw inc threads, if that's what it needs to blue? 100% clean, Elna red and heated ultrasonic bath + IPA rinse. Finally, there is definitely heat leak as there's about a 30c difference between the brass bed and the soldering station temp. Having said that, the bed temp was stable. I will try to search out a better brass pot, but I haven't found one yet, hence the stainless steel bowl.
    • Agreed but that's where WD40 excels, water displacement.
    • I would change the container to a thick walled brass one to start with. Looking at you screw pictures they don’t look shiny enough, really it’s best to do a black polish on them before trying. Also make sure once polished they are scrupulously clean, I dunk my experiments in acetone before bluing.   i think the thin walled stainless container to leach away the heat from the shavings, most successful bluing videos for example use thick walled brass to hold a good deep amount of shavings which acts as a better holder of heat.   Tom
    • …I guess my friend’s dad was duped…and by a Rolex dealer… …well, it’s a good fake 🤪 even the box and papers look legit…
