Pivot Sizes
Scouseget
I've been having lots of fun, and a good deal of frustration, working with a couple of English fusee pocket watches from around 1875. Surprisingly, I've been able to semi-master the intricacies of the fusee cone (dismantled, cleaned, lubricated, and reassembled) and chain (which was broken but I was able to repair it with the tiniest of rivets
), but am being presently stymied by a broken English lever arbor pivot on one of them. One end is not only broken but also missing so I can't establish the diameter, so my question is, are the pivots usually the same diameter on both ends of any arbor? This can be for a balance, lever, or indeed any other wheel arbor? Can we make that assumption, and if not, how do you make a replacement arbor, which is next on my work list for this watch, if you don't know what diameter to make it?
I do realize that I can simply try the remaining arbor in both jewel holes and try to establish the size that way, but it's a bit inexact and frankly I don't know how much clearance is normal, i.e., if a jewel hole is, say, 0.15mm, what size should the corresponding pivot size actually be?
I see that occasionally jewel gauges come on sale on E Bay, but these appear to be rare beasts at the best of times, and are usually prohibitively expensive so is there another method of measuring a jewel hole size?
Finally, why wouldn't the pivots be the same size on an arbor? Presumably the loading on each of the pivots would be the same so logic dictates that the sizes could also be the same, or am I missing something and making too many assumptions?
As always, thanks in advance for any light you can shed on this.
The first photo shows the broken arbor. The second is the fusee opened up. Amazing precision given the technology of the day I think.
For starters, you need the right tools to begin with. A good lathe and milling. The arbor is made out of a single piece of steel. You need to measure both holes in the plates and barrel, then you need to be able to draw up plans and design the arbor, taking a look at others will help.
Do you have a lathe?
You can then turn a series of trial pivots of a known size, pressed into a small brass handle.
1 hour ago, oldhippy said:
I wouldn’t think this type is expensive.
Depends on your idea of expensive.
Second hand anything from £50 to £120.
Its on my want list, but so are many other items
I think he was referring to my post which was about the pivot gauge for pivots, not your post about the hole.
On clocks you can measure the pivot hole with a smoothing broach and then a vernier or micrometer on the broach, I've never tried to measure the pivot hole on a watch, but can you do the same if you have fine enough smoothing broaches?
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
    • for the most part no. Each individual watchmaker and/or shop had their own system. One of the shops I worked at basically had a reference to a page number in a book. then there are some shops that do no markings at all as they keep their records on a computer and they don't have to mark the watch. Usually if somebody is marking and they've service the watch before you'll see those next to each other. then as far as anything resembling a standard goes at one time the American watch and clockmakers Institute assigned all of their members a number. but that was a very long time ago and I doubt that they are using it anymore.
