Pivot Sizes
Scouseget
I've been having lots of fun, and a good deal of frustration, working with a couple of English fusee pocket watches from around 1875. Surprisingly, I've been able to semi-master the intricacies of the fusee cone (dismantled, cleaned, lubricated, and reassembled) and chain (which was broken but I was able to repair it with the tiniest of rivets
), but am being presently stymied by a broken English lever arbor pivot on one of them. One end is not only broken but also missing so I can't establish the diameter, so my question is, are the pivots usually the same diameter on both ends of any arbor? This can be for a balance, lever, or indeed any other wheel arbor? Can we make that assumption, and if not, how do you make a replacement arbor, which is next on my work list for this watch, if you don't know what diameter to make it?
I do realize that I can simply try the remaining arbor in both jewel holes and try to establish the size that way, but it's a bit inexact and frankly I don't know how much clearance is normal, i.e., if a jewel hole is, say, 0.15mm, what size should the corresponding pivot size actually be?
I see that occasionally jewel gauges come on sale on E Bay, but these appear to be rare beasts at the best of times, and are usually prohibitively expensive so is there another method of measuring a jewel hole size?
Finally, why wouldn't the pivots be the same size on an arbor? Presumably the loading on each of the pivots would be the same so logic dictates that the sizes could also be the same, or am I missing something and making too many assumptions?
As always, thanks in advance for any light you can shed on this.
The first photo shows the broken arbor. The second is the fusee opened up. Amazing precision given the technology of the day I think.
For starters, you need the right tools to begin with. A good lathe and milling. The arbor is made out of a single piece of steel. You need to measure both holes in the plates and barrel, then you need to be able to draw up plans and design the arbor, taking a look at others will help.
Do you have a lathe?
You can then turn a series of trial pivots of a known size, pressed into a small brass handle.
1 hour ago, oldhippy said:
I wouldn’t think this type is expensive.
Depends on your idea of expensive.
Second hand anything from £50 to £120.
Its on my want list, but so are many other items
I think he was referring to my post which was about the pivot gauge for pivots, not your post about the hole.
On clocks you can measure the pivot hole with a smoothing broach and then a vernier or micrometer on the broach, I've never tried to measure the pivot hole on a watch, but can you do the same if you have fine enough smoothing broaches?
    • If you're seeking advice for your "Harvard GSD" MArch II application essays, I'd recommend taking a thoughtful approach. Reflect deeply on your experiences, passions, and goals, and tailor your essays to showcase your unique perspective and potential contributions to the program. As for resources, I recently stumbled upon a gret platform for essays, and I must say, it's been quite helpful. Their selection of pre-written essays covers a wide range of topics, and their professional writers can also assist with custom essays tailored to your specific needs. Check out their offerings here: https://essaypro.com/essays-for-sale. Remember, authenticity is key in your application essays. Good luck!
    • For clarity and ease of testing, I redid that diagram, flipping the circuit to match the layout of the physical watch.
    • Hello, Thanks for the reply. The old jewel will get pushed out from the "outside" which is the dial side. The new jewel will get pressed in from the inside (shown below) which is the movement side, correct?     And the old jewel and spring will get pushed from the is the "outside" which is the dial side. Thank you very much for the information. I will take out the KIF spring and save it. Will update when the new jewel is in place!   Regards, Joe
    • It's a little circlip style retaining clip to keep the pinion from riding up out of position.
