Movement ID?
Hi all,
Got my hands on another of these late 30's watches. Didn't run at first but soon found that the issue was due to a turn of the HS that had positioned itself over the HS stud and effectively prevented any operation. Possibly caused by the same guy who tried to top up the watch with oil via the winding stem inlet :-)
Once corrected, it ticks along nicely.
As I like to id the movements I fiddle with even if they are working, I have uploaded a couple of snaps for feedback.
The star-in-shield symbol indicates this should be a Venus75 but all photos I find (ranfft included) show a quite different bridge design even though the dial side seems to be identical with Venus 75.
Where variations of this kind common in these days?
Also curious if anyone knows about the letters ( A R. ??) on the bridge.
I suppose it's a brand id but since the dial and casing have no brand indication whatsoever, I'm happy for feedback.
Hi rogart63,
Maybe...? AR apparently comes from Aristide Racine, one of the founders.
I did some googling and there's for sure connections between Enicar and Venus. But they seem to be of more recent history.
Regardless it's interesting to see the large variation even within a caliber designation as Venus 75. I can't help wondering about the driving forces behind designing a special bridge to fit this base plate.
Was it just about having "your own" and being able to put your logo on the design?
Doesn't really makes sense in this case where the dial and case are completely anonymous and that's what the regular consumer will see...
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that. When cohesive forces within a liquid are stronger than the adhesive forces of a surface then surface tension is high causing the liquid to bead up. So  an applied epilame coating reduces the adhesive force of a surface inhibiting a fluid to wet the surface. So i guess no epilame cannot both repel and attract . If something is keeping the oil in place on top of an epilamed surface then there must be another reason for that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
