Temperamental Omega Constellation
Tomas
 Hello all!
   A vintage Omega Constellation came into my hands recently.  All appears to be well with it as it is clean and undamaged and functioning as it should, however.... it will gain several seconds a day when warm and will lose several seconds a day when in a cooler environment. What is going on here?
    Thanks.
       T.
1960's (?) vintage automatic wind Pie pan face, no date feature.   Temperature is from room temp (21C) to 36C ( in hot box). The movement has allegedly been serviced and lubed in the recent past.. so this is what i was told. Again, the movement is clean, bright and without any visible issues. Errors are  +- 90 seconds in a 24hr period.
Edited by Tomas
more info
How odd. Oil viscosity should only effect amplitude.
So, could the balance be at fault? Is it a smooth-rimmed glycudur balance or a screw-rimmed type with temperature compensation?
I would also make sure the tests are made with "all else being equal" and make a repeat of the tests.
It is a smooth rimmed balance. I was thinking this as well...if oil viscosity( wrong oil used in the wrong place) could be the culprit. The errors are practically nill if the test temperature remains constant.
Can you check the amplitude at both temperatures? Also, you might check the end shake of the balance. If it's tight at the low temperature, it could free up some at the warmer temp. Lots of other things to check, but I would start there.
Marty
I have not serviced the watch other than to attempt to adjust the rate. The story was that it had been serviced and likely cleaned by the good condition it is in.  Under the microscope, there IS evidence of oil throughout, including the pallet pivots. As per a previous suggestion, I I did check for end shake on the balance and found it to be noticeable. It would seem, given this, that there are compound problems at play to cause the rate with temperature variance. I do not yet have the means to measure amplitude.
You mean more oil is not better?
If there is oil on the pallet fork pivots, I would probably do a full service on this one and test it again. I do not oil the pallet fork pivots unless there is a cap jewel, and then only a tiny bit on the cap jewel and not the pivot jewels. And, I only put a minuscule amount of pallet stone oil on the stones by putting a small amount on the entrance stone and letting the motion of the escape wheel distribute the oil. We all have our preferences and there is more than one way to oil a movement, but some seem to work better than others.
 This one has captured my interest. Please post what you find the cause of the problem to be when you find it.
To much oil is not good no. My thought was is someone had just put some more oil in without doing a proper service before. Seen that so often i have started to forget how many i have seen. it.  Seller says it's serviced recently . Ya right :)
Edited by rogart63
  • 6 months later...
    • While you might have seen it as a humorous/Dramatic remark was done very deliberately so I could get an answer. Let me quote myself? The simplistic of this entire discussion is the group would like the last forever.   If you go to the top of the discussion group you'll find something to click on that says staff. Then you click on Mark's name and you find out interesting things? For instance he was last here on Saturday so yes he is here. If there is a crisis or a problem he is going to be here. You will also find a list of his activity although that's only the public activity. There's a lot of work that goes into running message boards and he probably does a lot of stuff in the background that we don't see to keep it going. Unfortunately message boards do not run themselves. Then regarding this did you notice you can message Mark and ask him. Then if somebody, we could elect somebody from this discussion such as @Neverenoughwatches To reach out I would really keep the message super simple like? You could refer him to this discussion but I would really keep it simple Like for instance the group enjoys his message board and what could we do to keep it going Forever? Then regarding all of the other suggestions comments helpful remarks or ideas? When was the last time any of you bothered to read the message board rules? This is covered which is one of the reasons I did the dramatic things I did to provoke a response of the basics as opposed to starting to suggest or seemingly suggesting all sorts of ideas which are covered by one of the rules found in the section on rules. In other words I'm going to quote something from the rules of the message board.
    • For me any input from Mark would be great. If he's keeping a close eye i would imagine he has read about our concerns here. But specifically i would like to know if he is ok with us collecting each others contact information for those of us that wish to provide them.
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
