Removing Hands from a Stopwatch/Timer
Does anyone have experience removing the hands from a mechanical stopwatch?  I read somewhere (I think it might have been DeCarle's book) that it wouldn't be easy and it sure isn't.  The hands are fitted tighter than any chronograph I've worked on.
The piece in question is a Horseman's stopwatch with an Excelsior Park 3-68 movement.  The amount of force required with standard hand levers is great enough to concern me about braking the dial.  The watch isn't mine and since it runs fine I'm actually leaning towards leaving well enough alone unless someone out there has previous experience and can advise how to gently overcome this hurdle.
Stopwatches are different then regular watches for hand removal. Usually with stopwatches the hands are not removed but the dial is removed with the hands. The hands are friction on with extreme force to a tube that on the backside has a heart shaped cam. So basically the hands go on spring-loaded cannon pinions with a heart-shaped cam used for resetting.
  • Like 6
Thanks for that John.  This does seem to ring a bell.  I'm glad I stopped when I did and asked the question!
  • 3 years later...
    • You need to know at least the basics. Then the questions that You ask will begin to make sense. From what is seen on the video, the gear train and escapement look fine, but the balance doesn't rotate free. I can suppose that the thin gold colored shim that must stay under the balance cock is not in place.
    • Yes, there are a lot of shapes and all of them are used in different cases. The one in Waltham A11 is one of the most spreaded and is what I have shown in the beginning. Of course, the radius of the final curve will depend on the distance between the hole in the stone and the regulator pins on the cock
    • I just found these. They don't really grab my eye at the moment, but having seen the change in some of the watches on here, before & after, the results have been pretty impressive. https://www.ebay.com.au/itm/196382906131?itmmeta=01HXBSJJXDB5J6H916ARJP9PHE&hash=item2db9555713:g:REwAAOSwUNdmOYAZ&itmprp=enc%3AAQAJAAAAwOAlUO3a1pAUX60Y8gUeXMPriraj5e7rkBNH2EA6cIUH7kb7hzoq6jRmOsYOQazk9R%2FteDESr1e50Asabv2tbJyDM%2FVODtmrAScFS4jPhHdgu6Jvt%2BFuRGBijpTkPl4NiK%2FDGr6qztc1Ujb33Tt6YdaUztOH9R1y9XJbwjH0puPDy8m0ilYcal7Vphcp7d59DLtBliNnbqfxfWhxdia2xMRyHYFHzR0Rg7NqB1z4xQGMZb73MAG4QBiF9FMkrII88Q%3D%3D|tkp%3ABk9SR_KuyvnqYw
    • I agree, it's getting harder and harder to find anything that meets the brief other than complete junk, or fake/frankenwatches. I would be in favor of raising the limit so people can continue to enjoy the challenge of resurrecting these low cost watches to their former glory and allowing the watchmaker the ability of practicing new skills without the worry of breaking the bank if all doesn't go to plan. Now all we need to do is settle on a value - maybe base the value on a standard currency so we are all playing by the same rules ($, £, €...?) Unless anyone minds I could start a poll and we could all vote on currency and value... let me know!
    • Same for me, but this is the first time I use the Bestfit. I understand that, for a 17-3/4 caliber, I have to consult page 150, but I can't find any resemblance. Thank you for all your research. I learn a little more each time I use this forum 😀
