Omega 1342 trimmer.
Hello, everyone,
I have an Omega 1342 watch that I need to adjust the time keeping ability of, using the
small internal trimmer.
The watch gains about 2 to 3 seconds per week, so I need to know which way the trimmer needs to be adjusted.
Clockwise, or anti clockwise?
Thank you.
That is almost like a chronometer 2-3 sec a week that is 1,5 minutes a year. I would probably leave hat as is . Adjusting 1342 trimmer is tricky as not just left or right. If you turn to much it could go over to - or +
I was thinking this was such a strange complaint until I realised we weren't talking about a mechanical calibre, but an early quartz, and I'm not exactly sure what the expectation should be with such a movement. I will say many people wear mechanical watches that are much much less accurate than that and don't consider it a problem, though. My Seiko for example, according to my timer should gain something like 15 seconds a day, but in reality, I never notice any inaccuracy.
I remember reading about quartz trimmers in a horology book before. if I remember correctly the results of adjusting it are completely unpredictable, a small nudge one way might add a lot of time, a little time, lose a little time or lose a lot of time, what ever way you turn it. I think you can monitor the effects through oscilloscope somehow, but trial and error would be your only way in all likely-hood.
Edited by Ishima
For this job you need a quartz analyzer. The watch should gain 0-15 sec per month not week. When you get an analyzer you can easily adjust a trimmer. I like to adjust them to 2 sec per month if I can.
When adjusting it is like adjusting the beat error in a mechanical watch you have to center it just right or it goes too positive or too negative either way you turn it.
Try to buy the Witschi Tech Handy Two. I have learned that servicing Quartz watches you can't go without one.
That machine is around £2,000. I'm not sure it's a given that everyone should have one.:wacko:
If you want to service Omega's you have to have one by Omega standard. If you don't know how to read your rate, consumption and coil resistance you shouldn't be servicing ETA's and up. Especially trimmer watches.
I can see the use for trimmer watches, the necessity, even.
I was just trying to point out the fact that it is £2k (and also really rather large) shouldn't be taken for granted.
Edited by Ishima
I suppose when considering a quartz movement we are trying to obtain perfection but in reality it's a nonsense. Unless you're engaged in some type of profession that requires complete accuracy such as " Global Navigation" 2 seconds a week or even 20 seconds a week or even per day, is of little consequence to the average person.
I think my old 1984 Omega 1430 gains or loses 5 seconds a week I can't remember. I wouldn't even consider having any adjustments made to it.
I would leave well alone !
Also as Ishima makes reference too " according to my timer should gain something like 15 seconds a day but in reality, I never notice any inaccuracy " Due to variables with a mechanical movement, may even prove to be more accurate than a quartz movement, over an extended period of time, due to the consistent nature of the quartz movement with regards to time gained or lost. In some cases anyway. Now there's a thought.
Sent from my SM-T585 using Tapatalk
My "thanks" to everyone that contributed to my question about adjusting the Omega 1342 trimmer.
For me, the Witschi timer is but a dream.
So it will have to be a case of small adjustments, lots of patience and making notes.
Regards.
Len.
I wish you well Len.  I believe the trimmer can regulates +/- 1.2 seconds per day, please don't go mad in the process of seeking perfection! :unsure:
Edited by Geo
Hello, Rogart63!
I don't know the answer to that.
All I do know, is that it is an 'in house' Omega movement and no other ETA movement will fit the case.
Out of interest, what difference would it make if the Omega 1342 is/was thermocompensated?
Regards.
Len.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
