Suunto Watch Repair
Does anyone know anything about Suunto Watches and how to diagnose issues and repair them without sending them to Suunto?
Thanks for the help.
Hello Ray,
I am assuming you're having a problem with your watch and don't want to send it back to Suunto to fix? I looked them up, and they look to be mostly quartz or digital type movements. If yours is one of these, it is usually easier to replace the movement when issues with function arise....You'll have to open the back and take a picture of the movement to determine.
J
Actually, no.. I am the watch repair person for an internet sales company and we have some defective Suuntos laying around and I don't YET know how to fix them.. And I thought I would collect some information on them first before I break one to learn more.
They appear to be more computer than watch. You might struggle to get a repair outside the dealer/manufacturer network.
Good luck, Neil
Yea.. this is what I am afraid of.. I don't have much experience with digital and electronic repair, I generally just replace circuit boards and whole digital movements when issues come up with those.
Thank you everyone for your assistance. I will do more research :D
Being a tool watch, the impact if it fails in use has to be considered. If this is not your watch then you may face liability issues.
A factory repair will be tested and guaranteed (and they have insurance).
Anils
I think the issue is, as mentioned above, that these are build around electronic modules which can't be repaired or obtained.
Not anything like liability, because in the end these are consumer products just like anything other watch, there is no law or regulation repairer responsability, at least in my country. Or do you think that Suunto would step in an pay anything more than a replacement, for any possible negative event involving their products :huh:
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
