removing ratchet wheel from pocket watch
Looking at the pics I would say the watch at some time has had water ingress and therefore it is rusted on. You need to soak with a rust remover for a few hours then gently lever it off from at least two sides being careful not to distort the wheel. I use horosolve rust remover and when the part has been removed some use strong tea.
5948c132f36bb_ScreenShot2017-06-20at07_29_39.png.8691e365224f74188be746ce5fb8958f.png
That is a five bar movement. If you have a pair of round nose pliers that should do it. A old pair of tweezers cut them back into stubs will work. I had an adjustable tool that was purposely made for this work.
  • 6 years later...
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
