It's about as difficult as I anticipated. An hour's randomised fiddling enabled me to refit the pallet/bridge But I'm having even more difficulty with the next longer pinion. How on earth you fit a bridge with more than one pinion I can't even imagine. I'm working on an AS "Trench Watch" with separate bridges - which I also anticipated would minimise this problem. But it still seems extraordinarily difficult, particularly with monocular vision. I only have stereo capability at about x3.5.
I guess the answer is "practice for about 10 years" however as that's probably about my total remaining life expectancy - if I'm lucky - so I'd like to accelerate the process a bit. I'd appreciate any tricks of the trade that might be offered - and apologise for the cascade of beginner's questions.
Roy
I occasionally use dentists tools to maneuver the wheels into place. Mostly though, it's practice, and learning how to see through a loupe.
Early on I put a 7S26C train bridge on and off over a dozen times just to get a feel for it.
Just finished assembling my test having cleaned it all yesterday. Many of the jewels were in bad shape and I suspect I haven't exactly improved them. It doesn't run of course...
Still, I thought that the balance would be the biggest problem as the sight of a hairspring gives me a nasty feeling, but that's fine. It's just the entire train that seems locked solid. Many hours spent and I hope not wasted. It'll be a while before I attempt to clean something of value. I have at least a hundred of these in variously bad condition so it'll be a while before I run out of cadavers to dissect.
Roy
I had to chuckle at this. Balances / hairsprings still make me twitch too as if anything's going to go wrong it's usually around this area!
I've also recently cleaned and, to my delight, got working an old AS multi-bridge movement as per the attached. Like you I thought that multiple bridges would make things easier but, and it's usually the escape wheel that is the trouble maker, it still took longer than I thought to reassemble!
I certainly always have the balance and pallet fork removed so it's easy to check for free spinning of the various wheels. I use a x5 (and sometimes x10) loupe and it's getting the movement at such an angle where you can easily see each pinion is vertical; not always easy on some movements! Even if I'm sure on this I only ever screw down the bridge(s) by teeny tiny increments checking for free movement of wheels all the way. Sometimes it's easy to see if a pinion is in a jewel (bright light; high mag); other times it's just a case of patience and gentle nudging. Always a nice feeling when those wheels whirr around smoothly!
Edited by WatchMaker
Attaching picture
Hi Skridlov,
pallet usually gets installed after the other train wheels but before the balance wheels.
When you say the balance is 'locked up', the first thing that comes to my mind is that the impulse pin is not in the pallet fork. Does the balance move one way but comes to a sudden stop the other way?
Anilv
Thanks to both of the above contributors. To clarify, the balance is actually free and with a couple of puffs of air oscillates in a very healthy looking manner but the escape wheel is reluctant to budge despite the pallet looking OK too. I think that the problem is in the train where numerous jewels are at the very least cracked and after US cleaning have started to disintegrate. I reassembled the movement despite this just in order to get a feel for the process. Overall I'm moderately happy for a first attempt - to date I've only successfully replaced mainsprings and sorted out a number of keyless work problems.
With the low value items I have - which describes most of them - the problem is usually a sticky hairspring; de-magnetising the whole movement and cleaning the spring with lighter fuel will often revive them. I'm seeing numerous movements which are otherwise pretty clean racing beyond correction by the regulator on account of this hairspring problem. Or that's what I assume.
I'll have another go at a similar movement. I probably have over 100 "trench" watches with some duplication of movements so I may be able to cobble up a few FrankenTrenchWatches. Better than scrapping them.
I bought some Elma(?) cleaning fluid from Cousins and also some Isopropyl. Overall, despite a non-working movement, I'm reasonably happy with the first attempt. But expect some further irritating questions...
Thanks again for the valuable tips, much appreciated. I wish I could reciprocate.
Roy
yes,  balance installed AFTER all bridges in place and TEST RUN  for smooth running.  that way,  the balance should start with one or two turns of the crown.  vinn
Noted, thanks!
Roy
Haven't any tricks but I've found that you need to have your head over the movement as close as possible but still able to manipulate the wheels in place. I find 8x magnification perfect for me.
If your moving your head or the movement to see if the wheel is in position, you're not over the movement enough.
Whether you place the screws in the bridge prior to final tightening, is a matter of preference. Whats very important is the bridge is held in place with gentle pressure while the wheels are manipulated into place and that pressure is maintained at all times during the tightening of the screws.
Constantly check the free running of all the train wheels during the securing of the bridge.
It's normally the escape wheel that tends to wobble out of place.
With adequate lighting, correct magnification, head position, you can see the position of the pivot in relation to jewel hole as you manipulate into position. Not so easy with a "bushed" movement.
Never attempt to assemble a movement if you have pressing business elsewhere or you have a self imposed time limit on the work. It's all about patience and being relaxed
Sent from my SM-T585 using Tapatalk
its art work lining up the pivots,  especially into capped jewels.  its much easier without the balance, but,  setting the balance is an art of its own.  vin
Hi vinn3,
I find capped jewels easier as the jewel is usually dished on the inner side, allowing the pivot to be guided into its hole.
Of course, the cap jewels need to be installed first.
Anilv
It's comforting (well, almost) to see that this is inherently difficult and not that I'm struggling with something others find relatively straightforward. It doesn't stop me imagining some kind of micro-jig though...
I've generally found that with processes like this - in software as well as hardware - there usually comes a breakthrough where the subconscious "knows" how to do tricky stuff. At my age though, that doesn't come as quickly as it once did. Luckily I've got a lot of similar dead movements to practice on. I'd thought of starting on pocket watches, of which I also have lots of movements, on account of their larger size but something tells me that's just avoiding some of the problems and familiarising me with movements that are too dissimilar.
And yes, there are definitely times when I need to walk away and do something else.
Roy
Roy
Definitely a good idea to walk away if things are not going well and come back to it another time.
I've struggled ridiculously to seat the wheels in the train bridge before, only to come back to the job another day and all done within 10 minutes.
There's no micro jig[emoji16] I suppose looking at modern manufacture, most production can be done by machine but to the hobbyist or repair/ small manufacturer, it's all about craftsmanship.
Really to achieve great proficiency, you require formal training lasting several years under a "Master"
Enjoy as a hobby and remember, all the disasters make the successes even sweeter
  • also,   if you don't use an acquired skill in 12 months -- you lose 90% of it.
Added to which the last n% of every job always takes 100-n% of the time required...
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
