ST6 wheel
Hi, please can you help with some advice about replacing the wheel, i pulled off in my haste?
i am still learning on my very first few movements, the ST6 movement was delivered from Cousins, and i attempted to pull off the 'mini hand', but succeeded in extracting the wheel, Noobie error i now know.
i assume i now have to start to strip the calender movement to get to a point to where the wheel can be replaced, then rebuild?
i read that there is also some form of friction to do with the wheel?
Man thanks
From your picture it looks like the hour wheel and cannon pinion have both been removed from the movement.  The cannon pinion is probably the piece which has the faux hand attached to it.  The pinion is part of the center wheel assembly.  It snaps into the center wheel and is held in place by the three curved spokes.
You may be able to secure the cannon pinion to the center wheel without removing any of the other parts but you may also find it easier to reattach the pinion to the center wheel on your bench.
The first step would be to remove the faux hand so that you can separate the cannon pinion from the hour wheel.  I also had the cannon pinion separate from the center wheel on a ST6D movement.  I found it not too difficult to remove the various calendar works bits that blocked extraction of the center wheel.  Once this was done I reseated the pinion on the center wheel on the workbench.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
