Seiko 6119 6400 help!!!!
Hi one and all, I have a Seiko 6119-6400 that I purchased with a broken off winding stem and missing crown. On removing the broken stem I found the new stem wouldn't "click" in, after taking excellent advice from this forum I found the stem release button had been pushed through too far. I removed movement from the case and then removed the dial, date ring, day disc, etc and put the parts that had been pushed out back in their correct positions and reassembled. Now when I push the crown in the date ring advances one day, but I can't get the day disc to move/advance. The problem is that I have never owned a 6119-6400 before and have no idea how it should work, I only found how to advance the date by accident and can't fathom how the day disc should be advanced. This leaves me wondering if it's my lack of knowledge or I have made a mistake? Any advice gratefully received. Johnnie
The day is advanced by pressing the crown a little harder. In that way you turn the day ring. There is a little finger on the movement that hits the dayring. Did you get the dayring in the right position when you put it on?
Hi Rogart, thanks for replying. I am not sure if I got that part right so will have to disassemble and look. The problem is that I really don't know where to look. Hopefully I will spot where I have messed up. At least now I have an idea what I am looking for.
Hi Rogart. This is where I am at. You are right about pushing crown a bit further, but when I refit the dial the date wheel will advance but the day will seems to jam up.
So you got a replacement crown and stem?
1. If you've trimmed the stem too short the crown will bottom to soon an won't allow full movement.
2. The crown design may not allow full movement.
3. If you are using a used crown, the crown may have dirt in the inside that prevents the stem to gVe full movement.
Try pushing the crown and see if the day changes.. if it does then your problem in the stem or crown.
All the best.
Anil
The day ring is is broken. The yellow ring in the middlle should come of to . And the star shaped part should sit on the dayring. Could maybe be put back together. But maybe it's easier to get a new dayring? Is it black or white?  124112V2.JPG.6d44c95b4f2b2f5d88b9a1be9b98965b.JPG
Edited by rogart63
3 hours ago, Johnnie said:
Hi Rogart, this is the day ring as it came out.
That is missing the star inside. I have one i think. Shall just see if it's the right one. Yours have 870 557 and mine has 870 559. Have a 870 670 also. But that has other languages.
Edited by rogart63
Hi Rogart, great! I am pleased something is missing, I was careful taking the day wheel off. Now wondering if the bit that's missing has been left behind if that's possible?
The part that is missing is still on the movement.  You will have to take the little brass ring that sits on the hour wheel off. Then you can remove the star shaped gear by lifting it up. It's tricky to put the star back in the right position but can be done. But need to be in the exact same place as it was before. Easiest is to replace the disc. Is it a 4 a clock crown on your watch.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
