Finally got a Seiko 7a38
ro63rto
Winging its way right now.
It's a non runner from Hong Kong and the bezel looks a little faded but should be a fun project.
Besides, if it is beyond my rather basic skills, I know a man in Berlin that can revive it.
Seiko 7a38-702a
Next will be the 7020 version Geo likes [emoji106]
Sent from my Honor 5c
     I have my share of 7xxx and other battery powered Seiko Chronos , but the 7A38 is my favorite .
In the past I have had about a 50% success rate in repairing them , but these can be a pistol to work on ,....mostly because if the circuit board is kaput , that's it .  I don't have the patience to work with the plastic gears mostly because of the fragile pivots , so I had a large stash of parts I sent to George C . where they will do the most good .
Good Luck with your incoming 7A38 .     BTW , The watch forum , 7A38 - by the numbers  , is a good source of info on this caliber .
http://seiko7a38.com/
Nice collection you have there.
I too have a few 7t watches.
7t34
7t62 asymmetric
I have a few others but Photobucket is playing silly monkeys and not letting me access all my pics.
This is my first 7a and hopefully not my last. I just refuse to pay the inflated prices some of them are going for so I buy cheap non working ones and keep buying until I can make one good one. Then I send them to George  when I fail or chicken out
  • 4 weeks later...
Well, bad news and good news.
The bad
But the good news is a VERY generous member on another forum sent me a working donor.
Only thing is.... I stuck it on a brown leather strap with gold buckle and can't bring myself to pull the movement to transplant into the first one [emoji4]
Now all I need is a working donor with a trashed case [emoji6]
That IS bad news and Very good news , and a little something in-between....I think .
Curious , Is the dial seated properly?  In the pic It seems to be lifted a bit from 10 to 3 . I have had similar circumstances where the dial wasn't seated all the way caused by the dial feet not being all the way down . I loosened the dial foot screw and was able to better seat the dial....sometimes .
Never noticed but I'll take a closer look. Might just be the angle and that shadow but we'll see.
OK , more good news..... Looks like you may have to zero out the minute subdial .
For that, it will need a case clean and rebuild with gaskets first. Will be ordering a load soon for this and 6 or 7 other watches.
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
