Mainspring for Tissot cal 27
Looking for a mainspring for an old Tissot cal 27 movement. Ranfft says 1.30 x 10.5 x 0.12 x 320mm , But the closest i could find on cousinsuk was 340 mm . But when measuring the old it's 0,13 and Jules borel says  1.30x 11x 0.13x 340. Which one would be best?
As the mainspring is of old standard i think 0,12 will do? But what do you think?
Using my "General Resorts"  ref: book spring is GR3515
Cal. 27 1.35 x 10.5 x 0.12 x 340mm  ⦱10
HOWEVER there are many cal 27,s listed but followed by a letter so be absolutely sure it is just a cal. 27
IE Cal 27 M spring is GR3338
Cal. 27 M 1.35 x 10.5 x 0.13 x 320mm  ⦱10.5
I am absolutely sure it's a cal 27. Only says 27 on the mainplate. But little strange looking at the size for that GR3338 on cousinsuk. It's says 1,30 instead of 1,35 .
But the last  will be perfect. As i think that is the closest to the original size i could find. And hope it isn't to strong? As the watch is from around the 1930-1940. Think we dated it to 1939 with the serialnumber.
Edited by rogart63
5 hours ago, praezis said:
Length 320 or 340 does not matter at all.
0.12 or 0.13 does. With 0.12 you may have a slightly lower amplitude but will avoid knocking (esp. after a good cleaning).
Frank
Maybe i should go for the 0,12 as the new mainsprings are much better then the old ones where? At least as the watch is from 1939.
When I searched Cousins for a Cal 27 mainspring it gave GR 3515 which is the same as the GR book suggests. If it was me thats what I would go with because it is longer so you will get a better standby time.
There is more here than I will ever need to know about mainsprings...
http://www.vintagewatchstraps.com/blogmainsprings.php, but I also read somewhere once that the height of the spring should be 0.2mm less than the height of the space in the barrel, although this is not easy to measure in practice.
The GR catalogue lists 2 different sizes for a cal 27; on the last page of this link https://www.cousinsuk.com/PDF/categories/7813_GR Pages 171 - 180.pdf and the first page of this one https://www.cousinsuk.com/PDF/categories/7814_GR Pages 181 - 190.pdf. Cousins parts finder for the 27 recommends the GR3515
In practice I would follow the advice which Frank gives above.  Modern alloy springs tend to give slightly more power than their historical steel counterparts. So where you have a choice, go for thinner raher than thicker.  The possible length is then an outcome of the available space per the first link above, and a longer spring will give more power reserve.
    • It started well. Got the clip off, cleaned in B-dip, bit of grease, then ping 😫. Lost the clip trying to refit it.    I'll get a replacement from eBay.
    • I used Google Lens on the pic and it suggested "motorcyle belt punch". And googling pics of that does show very similar tools. The end on mine is sharp, and does look suitable for punching holes in leather. I've no idea what belts on motorcyles would need piercing? The hole is about 1/4", so I cannot see a use in watchmaking. So, why have we both found one in a collection of watchmaking tools?
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
