I got this Omega 684 movement and it was keeping time to about 10 seconds a day but I've tested it now and it's gaining so much time and so out of beat the timegrapher is struggling to recognize it as a watch. I've poked the levers into every combination an it's still not working. What should I do now? Thanks for the help.
What happened between the first time and now? If it's gaining it could be magnetized or it could be oil on the hairspring. From the picture I can see the watch is running, but are the coils touching? Looks like they are. Check your hairspring coils.
Is the watch fully wound when you put it on timing machine and have you demagnetised it, is the hairspring flat and breathing properly and centred?
Edited by Tiktok
Are you sure the hairspring is between the 2 regulating pins on the regulating arm, if I remember correctly there is just 2 pins sticking down and the hairspring can actually jump out and rest against the wrong side of one of the pins, this would give an erratic reading.
It also looks like there is a hair from the incabloc setting towards the up side of the regulating arm, could this be hanging down and touching the hairspring or even trapped in the incabloc setting?
so in between 10 seconds a day and not being recognized what changed? Did it do it all by itself or was it the results of you pushing the levers wildly around?
So the beat adjustment lever is interesting in that there is no plus or minus. this means we are moving it in one direction if you moving too fast or you're not careful you can go past zero. Then very very tiny amounts of movement or you can be extremely far out of beat. Then the timing machine is averaging if you move too fast you can exceed its ability to read which are doing and once again you can go way beyond where you want to be very effortlessly.
so puzzling your picture is the regulator is so close to the stud it seems like it would be extremely slow? so it's very hard to tell in the picture I'm wondering if the terminal curve is where it's supposed to be? If you get carried away with moving the levers it's always possible to bend a hairspring. It almost looks like the spring may be off-center. If it's off-center far enough which I can't tell from the photograph it may be it's bumping into the back side of the stud or even the regulator pins. That would make it run very very fast.
It is for sure a hairspring issue. Either it has become magnetised, distorted or oil/dirt is causing the coils to to stick together. The regulator is way to close to the end stud arm so it might be way of beat or the regulator has been moved to far. I suspect your poking around has put it a mile out of beat so that arm is the one to be moved. I suggest before any more moves use very good magnification to inspect the coils
I agree. Look at the coil. Then deal with the regulator arm. As many have mentioned, it is too close to the end stud.
J
Poor thing looks like it could well benefit from a really good service, cleaning and relub. Those pics make it look stinking dirty, some parts have even gone green!
During this work, the fault will prob be self evident...
Come now @Alistair, stinking dirty?!? it's not all that bad.... is it?
J
28 minutes ago, Alastair said:
Maybe its the pics, but to me--yes, it does look terribly dirty!
Omega plates, wheels etc--Sparkle when clean...
Yeah I agree, Omega makes beautiful copper-plated workings that gleam when clean. But Titanium is a newcomer, and to him this movement probably doesn't look that bad. As you said, maybe it's the pics.
J
Edited by noirrac1j
It could do with a good service but I think even when cleaned the "green bits" on the edge of the plates I think he will find won't look much better, it looks like the oscillating wieght bearing/axle is worn (or at some point has been) and as it's been turning with too much play it has been catching the plates and damaged them, now the plating on the edge of the plates has worn off it won't ever look sparkling.
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
