Pivot or jewel
Depends on the tools you have. To reduce the pivot you will need either a lathe or a jacot tool. If you choose to change the jewel you will need a jeweling tool or you might achieve it with a staking tool. Both methods would work.
I have a staking set and a lathe but the lathe is a sherline 4400 I have no experience with either .I am not sure but I believe I need collets for the lathe so I can work on smaller pieces. So I guess making the jewel hole bigger is the way to go.. any suggestions on how to go about it.
Anthony
Sent from my SM-G900T using Tapatalk
I am not sure how to make a jewel hole bigger. There was a post on this forum a while ago doing this job using diamond paste & a Dremel. However getting the size hole correct is going to be difficult. If it was me I would just purchase the correct size jewel and replace.
Looks like it could be  @szbalogh video? He is the master of replacing jewels and repairing pivots?
If i would do it i would replace the jewel? If that is possible? think it would be difficult to enlarge the hole?
As you probably need to set the plate up in a lathe or some kind of device to get the hole perfectly straight?
Edited by rogart63
Looks like it could be  [mention=2058]szbalogh[/mention] video? He is the master of replacing jewels and repairing pivots?
I would rather do one repair or the other replacing parts is to easy..Been there done that.
Lol not, just butchering around :)
Jacot tool should be used to reduce the pivot diameter.
But here i would use the lathe with a wax collet. Just put a small brass rod in the lathe and turn a thin cone, fill it with shellack and put the wheel inside. It can be perfectly centered while the shellack is still hot. Then use a fine hone or steel with diamond paste to reduce the pivot diameter. The file should be supported on the parallel support to keep cylindrical shape of the pivot.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
