Is This Seiko A Fake?
  • 4 weeks later...
Went to register but looks like he doesn't take PayPal, only credit cards. I paid mine off 2 years ago and then cut them up. Couldn't trust myself anymore after racking up a huge debt.
Oh well, have to get my brother to register. Was hoping to get the watch sorted before he came back from Crete.
  • 7 months later...
Question.
Normally, on such a sealed waterproof case, the stem is in two parts so gets pulled out.
This one has a screw on crown, so no two part stem.
How do I take the stem out to replace its gasket???
Probably like my Tissot Seastar 7............. A REALLY GOOD PULL!
Looks like you are correct.
Weird though, when you order a crown, that's all you get.
Last time I bought a split stem, the crown had the male part attached.
Seiko case guide detail
Remove the crystal from the rubber gasket.
The rubber gasket will now be exposed and you should be able to replace the gasket without removing the crown.
Should you need to remove the crown, look into the gap between the dial and the case. You should see the little push piece in the gap.. I believe the crown needs to be out for the push piece to come into view but I may be wrong...try all positions if you don't see it. You need a slender rod to ally pressure while simultaneously tugging on the crown, I used a fine needle.
HTH!
Anil
HTH!
Anil
Hi Anilv,
I only need to change crown/stem gasket.
Crystal gasket already swapped along with NOS crystal.
There is no space around the dial to see setting lever.
By the pic in the case guide it looks like design is split stem.
Try gently lifting the edge while turning the crown? I usually turn them over and hold the case in my fingers, when the crown/stem aligns the movement just drops into my palm. This works for some types.
Anil
Anil
Dial won't move much but I'll try the turning it upside down trick.
Thanks.
  • 7 months later...
Where did you manage to get the gasket from in the end? Am looking for one myself.
I got it from Spencer Klein in Colorado but took aaaages.
Try sending an email to Adrian over at VTA in Australia. Very nice guy and always helpful. I now buy my reproduction gaskets from him. Perfect match and very good prices. Only takes 5 days to UK.
Edited by ro63rto
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
