Time Graph; What happend here??
Endeavor
Yesterday I adjusted the daily rate of my 25 year old Poljot 3133, but last night it ran a bit too slow. This morning I adjusted it slightly faster again but suddenly observed a weird behavior. Took the watch out the stand, "shook" it, but observed it again;
Since it was still a bit too slow, I adjusted it a bit more, which yields now the following picture (note; the last two dots out of line is me preparing to switch off).
Took the watch "for a walk", observed it in the Watch-O-Scope for several times now, but the line stays "flat" as in picture below ........
Anybody any suggestions what happened here and what caused it?
Edited by Endeavor
@szbalogh Very interesting! I got into the habit to wind the watch each morning, and before it was put on the W.O.S, it was just fully wound. The main-spring is the original Poljot. I had this watch already multiple times on the grapher and so far it ran like a dream, with no irregularities whatsoever.
Reading the above, and if this is indeed the cause, and if I don't see it again, I just leave things as they are. Perhaps it just got out of bed on the wrong side, on a Sunday morning ;)
It's possible that there is contamination (oil) occasionally causing the coils to stick.
But as Szbalogh points out, your amplitude is awfully high and you may be hitting the bankings as a result. When it's doing this, listen to the watch as it will start to sound like a horse galloping. It's potentially not very good for the escapement.....
The watch was just fully wound, till "end-stop" and then put on the timegrapher. As far as I remember, all the other measurement I've done preciously were later in the day. The watch has just had a service a few weeks ago. Perhaps I shouldn't wind it fully?
Also, since @szbalogh came swiftly with a plausible answer, I ordered the book "Practical Watch Repairing" by Donald de Carle. I figured, that after a year tinkering around, perhaps it was time to get a bit more in-depth know-how :)
Edited by Endeavor
7 hours ago, Endeavor said:
Interesting lesson learned ! Thank you all for your input :thumbsu:
BTW; for as long as this "Practical Watch Repairing" by Donald de Carle" eBay-link last, seems to be the latest (2008) print;
http://www.ebay.co.uk/itm/172520638123?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Have that book but i think mine is from 2013? Says inside that there was last reprinted 2013.
1995,1996,1998,2000,2001,2002,2003(twice),2005,2006,2007,2008,2011,2013
You never want to wind the watch up tight and put it on a timing machine. The factories have recommendations Such as ETA has this "All check are made without the calendar in function and chrono not coupled. The check has to be done at full winding, referred to as 0 h, after 1 to 3 hours running." . Omega uses "0h Measures to be made between 30 and 90 minutes after fully winding.".
If you run a time plot of the watch fully wound up tight you will see variation for the watch to stabilize. Modern watch in nice condition seems to stabilize really fast personally I usually wait 30 minutes seems to be fine for timing.
Then if you're timing in various positions you also should allow a little bit a settling time for this I use what Omega recommends for vintage pieces 30 seconds between positions. I do notice for non-vintage Omega watches anywhere from 15 seconds to one minute but most of them at 30 seconds.
@JohnR725 That seems to be some nice guidelines. Another reason I fully wound the watch, was to have a spring-tension reference point. Obviously I didn't expect this behavior to happen. To let it run a certain amount of time, one, two or three hours after being fully wound makes sense and still provides a spring-tension reference point.
Thanks for the tip ! :thumbsu:
@rogart63 I googled the ISBN number and the information was a bit unclear; 2008 it said. It may well be that the book in the link is a later re-print, but it doesn't say. I have to wait until I receive it to be sure ......
Edited by Endeavor
Probably is the same text inside? Mine is not the soft back version as this is? Don't now what is called? Has a hardback and a paper outside to protect it?
Looks like there is a lot of different versions out there?
This is how mine looks. 58ab14c48132c_62224practicalwatchrepairing.jpg.d671c51c724dc8bf29f37483913f7d22.jpg
    • You need to know at least the basics. Then the questions that You ask will begin to make sense. From what is seen on the video, the gear train and escapement look fine, but the balance doesn't rotate free. I can suppose that the thin gold colored shim that must stay under the balance cock is not in place.
    • Yes, there are a lot of shapes and all of them are used in different cases. The one in Waltham A11 is one of the most spreaded and is what I have shown in the beginning. Of course, the radius of the final curve will depend on the distance between the hole in the stone and the regulator pins on the cock
    • I just found these. They don't really grab my eye at the moment, but having seen the change in some of the watches on here, before & after, the results have been pretty impressive. https://www.ebay.com.au/itm/196382906131?itmmeta=01HXBSJJXDB5J6H916ARJP9PHE&hash=item2db9555713:g:REwAAOSwUNdmOYAZ&itmprp=enc%3AAQAJAAAAwOAlUO3a1pAUX60Y8gUeXMPriraj5e7rkBNH2EA6cIUH7kb7hzoq6jRmOsYOQazk9R%2FteDESr1e50Asabv2tbJyDM%2FVODtmrAScFS4jPhHdgu6Jvt%2BFuRGBijpTkPl4NiK%2FDGr6qztc1Ujb33Tt6YdaUztOH9R1y9XJbwjH0puPDy8m0ilYcal7Vphcp7d59DLtBliNnbqfxfWhxdia2xMRyHYFHzR0Rg7NqB1z4xQGMZb73MAG4QBiF9FMkrII88Q%3D%3D|tkp%3ABk9SR_KuyvnqYw
    • I agree, it's getting harder and harder to find anything that meets the brief other than complete junk, or fake/frankenwatches. I would be in favor of raising the limit so people can continue to enjoy the challenge of resurrecting these low cost watches to their former glory and allowing the watchmaker the ability of practicing new skills without the worry of breaking the bank if all doesn't go to plan. Now all we need to do is settle on a value - maybe base the value on a standard currency so we are all playing by the same rules ($, £, €...?) Unless anyone minds I could start a poll and we could all vote on currency and value... let me know!
    • Same for me, but this is the first time I use the Bestfit. I understand that, for a 17-3/4 caliber, I have to consult page 150, but I can't find any resemblance. Thank you for all your research. I learn a little more each time I use this forum 😀
