Fix For Balance Wheel And Spring
Hi everyone,
I took a preliminary view of this movement ( looks like someone was using it to dig a trench) and I noticed the balance wheel and spring have come apart. This may be may first opportunity to fix a hair spring. Only I don't know where to start.
It is hard to see, but the end of the hair spring is attached so what appear to be part of the balance cock which has in turn become loose. I can't figure out how that spring came to be on top of the balance cock and where to affix that end (looks like a ring).
Any help will be greatly appreciated and I thank you in advance.
Hi Robert, you really have a tricky problem here, so here's my take on it.
It looks like a Seiko movement,and the part that is free (for setting the beat) should be underneath the regulator.
There should be a small screw securing the hairspring stud to the piece that is loose. Slacken this screw and remove the part from the hairspring.
Remove the remaining parts of the balance assembly in the normal way and pin it upside down on a piece of cork to make it easier to work on.
Turn the movable guide pin on the regulator to allow the hairspring and balance to be removed from the cock. Place the balance out of the way to be worked on later.
Now assemble the balance cock assembly correctly with the regulator on top of the beat adjuster.
It's now time to sort out the hairspring. It should be perfectly concentric with the balance staff and flat and parallel to the balance wheel. If not, then here comes the hard bit. You will have to stroke it very very gently to get the desired shape. I used two pairs of fine tweezers for doing this. Be careful not to twist the spring in the process, or it will not slide smoothly through the guide pins. If you are lucky you may manage this with the hairspring still attached to the balance staff, if not, remove it having first noted the position it is fitted relative to the roller jewel. ALL OF THE ABOVE IS VERY DIFFICULT AND YOU MAY END UP TOTALY DESTROYING THE HAIRSPRING.
If successful, reassemble and let the timing begin. You will have to adjust the beat first then regulate it.
Have fun!
Edited by Geo
Excellent instructions Geo, I appreciate your help. I'll do exactly as you say. This is some sort of Seiko clone I got in a batch of movements "for training purposes". If I screw up it is no big deal although I would prefer not to. Somehow I get attached to those poor, mistreated movements regardless of pedigree!  :nurse:  I can easily tell you, this one never had a gold case for sure!
In any case, I'll get back with any developments (I'll be working on it in the morning)!
If that is a clone, could the the beat adjuster possibly be mounted on top of the regulator? I' sure it will be clear how it goes when you study it with a lupe.
I meant to say that when pinning it to the piece of cork, I use a small screwdriver through the screw hole in the balance cock.
Hi Geo, I did part of the job but had to interrupt it for other matters. The balance is free and the spring is as fine as possible (I had to play with it but in the end I managed to leave it in almost pristine shape). That's what took so long.
Absolutely, the beat adjuster does go on top of the regulator as you rightly guessed, I just have to find a way to attach it there my guru friend! ("looking around my work bench and figuring what to use, mental inventory: hammer, chisel, metal saw,.... too big, tiny watch screwdrivers... I guess not, rodico, super-glue...ok back to that later...no pinning stuff in my **BLEEP**nal yet, 'will have to improvise!") :phew:
I will assemble the whole thing either tomorrow morning or tonight when I get home from work. Then it will be time for full disassembly of the movement, prep for cleaning, ultrasonic bath, x20 inspection and if everything checks, reassembly and testing. Thanks for your help, I'll keep you posted of new developments and post a picture of the wheel and cock complete.
Robert
Hi again I got a problem with a air spring,the air spring has broken in two just past the regulator part,so balance wheel no longer on spring,can I repair this on my bravingtons watch or can I get a new spring to put in the watch,hope any one can help
Repairing the spring is not an option, you will have to fit, or have fitted a new hairspring.
Hi Christopher, if you have good experience taking watches apart and servicing them, then you may be ready to progress to the highly delicate job of fitting a hairspring, if not I suggest that you take it to a professional watch repairer to have it replace.
Could take a high definition picture of the movement, to allow identification of the movement. Bravingtons used movements from different manufactures in their watches. This is required to see if a hairspring is available.
Hi chriseames168, when the movement is identified -- just as Geo said -- and if you are in the US -- or want to try this option --, otto frei has all sort of hairsprings to be fitted. You only need certain specs (regarding the wire dimensions, as listed in his page) to have the right one sent. Once you get it, you can fit it, which might involve some cutting to size and "fabricating" the proper dog leg, etc. Alternatively, he may have a complete balance/hairspring assembly available...I recently ordered one (without the cock) for an eta 2801-2. It is a little pricey that way but most of the work is already done for you, specially if you don't have the right tools or the experience in that kind of job.
An update about the original thread:
I was able to re-attach the actual parts to the cock. They are held in place by a U-clip that attaches to the lower jewel housing. This housing has a lip all around that holds down both parts of the regulator (rings, one of them loose originally). My solution -- thanks Geo for valuable instructions -- was to "think inverted", i.e. upon disassembly, I set up first the jewel assembly, upside down, on the bench, on top the two regulator parts and finally the cock upside down. Holding/pressing down with tweezers the jewel housing protrudes from the cock enough to insert the clip back in place. Now with the whole thing re-assembled is time to re-attach the hair spring. Pictures will be coming soon....to be continued.
Thank you Geo, I've been working on this on and off since it requires lots of time and patience. On the other hand, I was looking at this bunch of movements (Seiko like, not Seiko) and they have a different shock protection system (as in the original picture in this thread). I don't know if I ever said that I lost the bottom part of a 7S26 diashock assembly, the one on the main plate. Maybe much later when I'm done with the "hairspring movement" I'll "transplant" one of these easy to work on shock systems  to the 7S26 plate and see if it works...OK this is work in progress for now but I'll post the results in time.
(This is hilarious, I was trying to edit and clicked in the "like it" button!! ooops!
Edited by bobm12
I've managed to ascertain that the movement in your watch is an ETA 1256. I would suggest that you buy a movement with a good balance wheel and hairspring on EBay. Here is a photo of the movement, maybe someone on the forum has one lying around and can help you.
Hi Geo, is your middle name Sherlock by any chance? :thumbsu:  I think I have a "practice" movement that came with the same/similar automatic system but is not ETA. Some sort of clone (of something). The balance is shot so it is useless even if it ever fits, sorry (I would have donated it for a good cause if at all usable).
I wish!
Christopher could not manage to post pictures so he emailed them to me and asked if I could help. The resolution was low but there was enough information for me to guess the calibre number. I then found a hi resolution photo on the net and used that. Being ETA it has been used in many high end watches, so picking up a movement on EBay is a good option. The movement dates from between 1950 & 1954.
this is confusing.. first we're talking about a seiko and then an ETA1256?
Anyway.. the ETA is one of my favourites...
1.it was the first autowind by ETA ..
2.On most of the ones I've seen the automodule screws are labelled 'A' with instructions on the rotor to 'remove 'a''. I can imagine back in the day when auto's where 'new-fangled' and watchmakers had to be guided thru this amazing new technology.
3.The dial feet are symetrical.. it is possible to make a 'left-handed' watch for your lefty friends.!!
Anil
Hi Anil.
The confusion was caused by Christopher coming in with hairspring questions not related to the original post by Robert!
Here is an update of the work involved, after this step we will re-attach the balance and spring. Notice that the outermost part of the regulator is where the hairspring is attached. So basically we are thinking inverted since the cock is upside down for assembly. More to come...
Oh, I've been having "fun" with this movement ever since I started fixing it,
First, I lost the camera SD ship to take more pictures, but I "passed" that step (I reassembled it)
Then the SD ship re-appeared and I disassembled the whole thing to take the pictures above.
Then and just after that final picture, I lost the clip! It just jumped into nowhere.
Now we need to wait until I lose another part and in substitution the clip reappears!
Edited by bobm12
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
