Inca bloc Cataloge
Picked up this from the bay this week a really useful catalogue with info on Incabloc. It shows the sizes the jewels & springs etc. One thing I have picked up already is, not only are the cap jewels not always that same for the upper & lower but also the springs are sometimes different for the upper & lower.
IMG_1087.thumb.jpg.273f5211ed1753b8cb3eaabad1ecb677.jpgIMG_1089.thumb.jpg.fe1bde6aac9f262f5d3062e3c32bbc89.jpg
    • Back home...printing now.  Will report results
