Greetings from St. Louis
Israel Slick
Hello Israel,
Its greetings and welcome from me as well.
Hope you enjoy it here and all will look forward to your postings of your favourite watches (hope you like old ones) and any work you care to show, help will be given if needed by the members and we are not afraid to be light hearted on occasion either.
Cheers,
Vic
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
