Watchmakers balance tool
Douglas1701
As soon as I can drag my butt out of this chair and away from this sweet tea nectar, Im gonna go and try to make some handles for the oilers and maybe an oiling station to go with it. Local walmart has some of those paint pots for kids, thought they might work good for holding the oil and grease.
keep ticking away,
doug
keep ticking away,
doug
Thinking out of the box ,....I like it .
4 hours ago, szbalogh said:
One can however ask if the hairspring get distorted while hanging on the tool? Well, the most sensible part of the HS is at the stud, where it can easily bent if the compass is not moved to the fastest setting, or the HS is out of the compass. I have a watch with a big balance and relatively thin hairspring. It has experienced noticeable distortion after having a journey on my balance tack. I think one should check if the HS is flat and is half way freely between the regulator pins at resting after mounted back in the movement.
That is my fear as well; I only use the balance tack when adjusting for beat error.  I'm not sure how rational this fear is, but I've straightened enough hairsprings to know it's my least favorite part of the job!
Nice work Douglas indeed. I always check my pivots on a tack you can look around the hairspring and jewels alot easier and its safer if your careful and dont go wildly pulling at the balance and distort the hairspring.and its an excelkent way of holding the balance clock while you adjust the collet on a staff for adjusting beat error when your balance cock doesn't have a beat error adjustment feature.
20 hours ago, Vich said:
Looks good as well as being functional, go into mass production (for forum members only - at a reasonable price of course emoji6.png)
Cheers,
Vic
21 hours ago, rogart63 said:
Nice work. Measured a Bergeon black oiler and it was approx 6 mm and 50 mm long. The oiler was 1,5 mm and 0,18 mm in the tip. That you have to buy i think? But they could be bought as spare parts.
Thanks for the measurements, got the oilers done, will post some pics in a bit.
59 minutes ago, Douglas1701 said:
Well, got the oilers done...made them out of walnut again...made the knob at the ends different sizes so I would know which one to grab. Gotta figure out a way to make caps for them and then onto the oiling station.....
Beauties? If you do the end smaller you could maybe use some covers from ballpoint pens? Like on this oilers.download.jpg.bdb03afdd41282f6af2637f81884405e.jpg
Im getting close, decided to incorporate the oilers into the station. Still got another day or so on it, but im further than I was...lol......gonna make a place for the balance tool to sit in when not in use so it doesnt get messed up....may move it to one side instead of the middle....any thoughts?
Edited by Douglas1701
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
