Bergeon hand fitting tool magnetized?
Ishima
I have a Bergeon 7402-2 hand press tool, and recently (I've had it for a number of months before this issue cropped up) it seems to be constantly magnetically attracting the hands to the supposedly plastic tips? It's becoming a source of consternation, I keep running the tool over the de-mag and sometimes alternating with de-maging the hand I'm trying to press, after several attempts it usually fixes the problem, but tomorrow I'll pick it up and it will likely do the same thing, it's not stored near anything I could think would cause it. And with the plastic tips I'm not sure how this is even possible? My other bergeon hand presses haven't given me trouble, just the 7402-2. Am I alone? does anyone have advice?
Try an antistatic strap, the same device used by electronics technicians to remove static before working on sensitive electronics.
The alligator clip goes to a grounded metal plate; the bracelet goes around your wrist.  It will drain off any static charge in your body as well as tools you may be holding.
Or this kind of thing
http://www.somersetsolders.com/anti-static-spray-for-plastics-hard-floors-and-non-porous-surfaces/p403?gclid=Cj0KEQiA5IHEBRCLr_PZvq2_6qcBEiQAL4cQ07qKVckV9OSRrykG9o7joPhSVphuAdmG-28zqj7BGpEaAgjn8P8HAQ
I assume from your description that you are definitely dealing with attraction, not stickiness and that its most likely static, not oil.
The wrist strap may help, but in an electronics environment it should be part of a system which elimantes most causes of static build up and provides a dissipative path (not a direct earthing path, but through a resistor) for any that do build up.  Special flooring, shoes, lab coats, bench mats, etc.
Agreed. The earth grounding point in an electronics lab has a 1MOhm series resistor to limit current.  That is a safety measure because the operator is working around potentially lethal electricity.  There is no such threat when working around watches.
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
