Free Moebius D5 with short shelf life
MikeAdvicePI
I have some Moebius D5 I bought from Cousins last year. It's a 20ml bottle which I'm unlikely to finish in my lifetime, let alone between now and the end of April 2017 which is the shelf life expiry date of this batch.
I haven't been able to find a clear answer to just what the expiry date means for the oil in the bottle. Does it mean the oil should no longer be used from that date? Does it mean that if you use it at the end of the shelf life period the oil will do its job for another two or three years in the watch? Either way, as a tinkerer I'd be content to use it for the next couple of years. That would still leave me with more D5 than a hobbyist would ever need, so I'm planning to keep 2ml and I'm offering the rest of the bottle to other tinkerers in either 1ml or 2ml doses.
I have some new small 2ml glass bottles, an unopened syringe and a blunt mixing needle to decant the oil without contamination. You can have it for free, but I'll provide my paypal address in the package if you want to make a voluntary contribution to the P&P. If all of the oil is taken I'll post an update in this thread.
PM me with a postal address and tell me whether you would like 1ml or 2ml.
  • Like 7
Interesting regards oil shelf life. Synthetic has practically replaced the old type oils. I wouldn't rush to dispose of your surplus d5. I would be happy to use in 2017 and service the movement or inspect it 3 years later. As a hobby where low volume of oils is going to be used, mobius 9104 is a far better choice than d5. It's suitable for all d5 applications and is fully synthectic and is good for 5 to 7 years at least.
I sort of think regards shelf life while the oil is reducing friction, lubricating, not gumming up, it's good to go.
I suspect specific shelf life is more to do with marketing ploys than reality but it shouldn't be ignored
Sent from my SM-T585 using Tapatalk
I suspect there's a lot of snake oil (pun not intended) in the watch oil industry. Synthetic oils are not necessarily better in all respects, and natural oils have their own advantages in some cases. I wouldn't be surprised if this bottle of D5 was perfectly useable for several years. Perhaps the only fair way to test would be to leave droplets alongside some alternative oils and monitor how they deteriorate over a long time.
  • 2 months later...
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
