I have a Rotary watch GB42826/08 but having trouble removing the back. It seems to be a snap on but won't budge? Do I have to remove the crown first if so how. Thanking you in advance.
modern Rotary watches like this have notoriously tight case backs, with a very fine lip for the tool to pry on.
If you don't have experience and the right tools, forget it, find a watchmaker. You'll also need to get this back together once it's open which will require a case back press. No you don't have to remove the crown.
Edited by Ishima
I have 2 Rotary watches and yes, the cases are REALLY tight. Even watchmakers have trouble opening them freehand, a case pry tool is the only way to go, unless you want to try your hand with a very thin dull knife blade and risk slashing yourself in the process.
