How Old?!? Not A Clock Mechanism As Such...
There is extensive information about this 2,000 year old "Computer" on the Internet,  it was used to track the planets, predict eclipses and show the time of the Olympic games,  not bad for 2,000 years ago.  It was another 1,000 years before anyone else managed a gear based mechanism of this complexity.  It is called the Antikythera Machine after the place where it was found,  about 100 years ago,  clever people the ancient Greeks.
I saw this some time ago and as Roger says there were some incredibly clever people back then. To be able to work out the the mathematics then actually manufacture a device as complicated is truly mind blowing. Even today it would be a massive, or should I say a mathive achievement.
  • 11 months later...
I just finished a book about the Antikythera Mechanism called "Decoding the Heavens" and tonight I re-watched a Nova episode about it.
Fascinating subject on its own, but also as it relates to clocks. In the book it says that early clocks in Europe incorporated astronomical displays that were "spookily similar to their ancient predecessors such as the Antikythera Mechanism" and "The speed with which these astronomical displays became so elaborate and so widespread - and their similarity to those developed by the Greeks - suggests that all this did not emerge from scratch. Various pieces of the necessary technology, and the idea of using gearwheels to simulate the heavens, must have been lying dormant in a range of devices - including water clocks and hand-driven calendars - so that when the invention of the escapement allowed the construction of a mechanical clock, all of these old tricks came rushing out of the wings into the new tradition."
One of the most interesting characters in the book is Michael Wright, who made a working model of the mechanism using hand tools such as would have been available in ancient Greece. In the Nova video you can see some old pocket watches in the background of his workshop.
https://youtu.be/4eUibFQKJqI
What I cannot figure out is how it was operated,  there is a knob on the side which when turned operates the gear train and moves the pointers.  To me it seems a bit like a wind up perpetual calendar watch in that if the watch is ever allowed to stop it will quickly be out of synch.  This means someone had the job of operating it the required amount everyday,  one can imagine the pointed fingers if ever they forgot.
If anyone can explain better how it was operated I would be very interested.
My brain is hurrting thinking about the machine, never mind what kept it running. Maybe they threw it in the sea because they couldn't biuld a driving mechanism (clock) that could hold accurate time!
  • 1 year later...
  • 1 year later...
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
