Waltham PW Mainspring Disassemble
MrBeat
Happy New Year All :)
Well its a good start to the year and ive already come unstuck.
I don't usually work on American watches but i have a Waltham that requires a new mainspring and ordinarily this is a non issue but i can not see how the barrel comes apart to change it as it seems stuck in place ? Does the barrel arbour get punched out ? I can not for the life of me see how to get this out it seem intent on staying in ?
Any help with pointing out my obvious error will be most appreciated, Photos Below >
It appears theres play but the thing does not want to come apart, am i missing a secret here ?
Well the penny dropped :D
Turns out the arbour is a two piece that screws together, although this one had ceased and just needed an extra umppfff to get her to release. Apparently this is a common assembly on Walthams of 19 Jewels ( this case a Cresent Street ), a small and old picture on the interwebs from Waltham shows the assembly which is why it had me baffled for a moment.
Now the parts are cleaning before new spring is fitted, problem solved :)
  • 4 months later...
@MrBeat @oldhippy I'm in the middle of replacing am mainspring on a Waltham 12s and I'm having similar trouble.  I thought maybe the plate held the assembly together, but it's near impossible to install without the mainspring lifting the cover slightly off the barrel, unseating the pivot.  I had no trouble getting the arbor out though, this one appears to feed through the assembly, but there is no means to keep everything captured prior to installation.  Really stumped here.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
