Building My New Watch Repair Workshop.
Mark
The shipping cost cousins is charging is really ridiculous.
The bench light costs 74£ and the shipping is another 63£!
I have ordered a lot of stuff from cousins, mostly watchparts & small tools. For these items the shipping costs is reasonable.
But for this case it just makes no sense.
£63 for delivery is a bit excessive to be fair.
I just paid £8.99 for the 48hr service, it should not be much more in reality to send to your location which is not a million miles away.
I hope this light plays well with my recording. At the moment I use a magnifying ring lamp (with the magnifier removed) to enable the camera to see directly down. But the lamp does get hot and I would guess the colour temperature to be more in the region of 3000 which is much more yellow. I always find myself craving natural light. Hopefully these issues will be resolved by the end of next week :)
I like the look of this lamp but I don't like the price so I have it in mind to build my own.
I reckon I can pick up the bits I need for about a tenner.
My wife uses these for her doll's houses; eBay #141472381811.
It's £4.99 for 5m delivered which will give me 24W of light if I use the whole lot to make a 50cm x 8cm panel, against 21W for the Cousins item.
Add this for power; eBay # 201270927022 @ £3.59 delivered and that leaves me £1.42 for a switch.
I have some 1.5mm aluminium sheet in the shed to make the panel, and some square dowel to make an articulated boom.
This is definitely a project that I will undertake in the near future. It probably won't be as pretty as the Cousins one but I don't mind that. I will post pics when I do it.
I also have an upgrade for my microscope and camera lighting on its way but as that is a birthday present I can't reveal more at the moment.
I like your style Marc. I had intended to do something similar myself having kitted out my whole kitchen for less than £30. The trouble is I have so many projects on at the moment it would possibly never get done and the Cousins one was perfect for my application.
Please post the final result. :)
The Cousins lamp looks great and reasonably priced if you're in the UK. I'll have to scour the internet for a similar lamp available in the U.S.
Looks like a cool project, Marc. I'd like to see the outcome too.
I've been thinking about using 4 of these Nichia leds that I already have from another project thermally expoxied to some flat bar aluminum for a heatsink. I have a 350mA driver too, but I figure that will only get me about 400+ lumens. I may try a 700mA or 1A driver and see what kind of output I get. I was hoping to find a used tube lamp to put everything into. The leds you're looking at say they output 270-300 Lumens/Meter. Are you planning to do more than one row for your light?
Don
Edited by Don
Don
Reef or Plant light?
Edited by BlakeL
Actually, I was going to mod some flashlights with the Nichia 219 and maybe make a work light. It's a great led with a nice color temperature and high CRI. And it's pretty much a direct replacement for the Cree XP-G.
Just a quick update. Finished installing the units and cut the surfaces. Electric sockets are in place and wired in.
Just need to raise the watch repair work area to the desired height.
I will lay the floor tomorrow.
Thanks guys.
Didn't manage to lay the floor. I had quite a lot of wood left over so decided to put it to good use by building a new desk for my computer and recording stuff. Spent the whole day yesterday on it and should finish that today. Then I can lay the floor (less dust). After that, laminate the worktops, fix the architrave's and skirting boards, move in, start working! :D
Finished the desk (mostly). Quite happy with it. Space for my screen, two reference monitors, 8u of rack space for audio equipment ( I have a 2u tube preamp and hope to get a compressor in the future).
The pc can sit nicely below. Just need to sand and varnish. Very happy :)
Hi Mark, i see you plan on getting a compressor?  I get through quite a few cans of compressed air per annum, and the cost stacks up @€10 a pop, so have been looking for a more cost effective solution, and a friend of mine, also a watchmaker, he uses a Scuba divers air tank.  It costs less than a can of air to fill, and it lasts a year.  Reason I will be going this route too is its quiet, as my workshop is in our large living room, this would be the best viable solution for me.
I was talking about an audio compressor - it's a little hobby of mine to mess about with music.
That's a great idea regarding the scuba tank. I currently use a bandit compressor for removing dust prior to watch assembly in the case but it is hellish noisy when it kicks in.
However, it does double up as a tyre inflator and a nail gun :D
    • Drilling is going to be difficult, firstly because the drill bits are so thin and brittle, expect to break a few. The second issue is access to the 'hole', as the other lug will be in the way, meaning that you will have to drill at a slight angle, putting a bending stress on the drill bit and with the slightest drop in concentration .... and back to my first point. I would be tempted to grind them flat with a Dremel type tool or small jewelers file, and then put a center punch in the center of the bit to be drilled so the drill bit doesn't skip around and break... but expect this to be slow and frustrating work. By the time you have done 4 of these you'll be an expert and can come back and tell us all the best way to do it if you go down this route. However, I would seriously consider What @watchweasol said and drill from the outside-in, this will ensure straight holes without having to work around the other lugs. It may be worthwhile making yourself a simple paper template so you can be sure to match the position of each hole before drilling. In the end you will be left with 4 holes on the outside of the lugs, but many cases are made this way and unless you are looking for it you probably won't notice or realise that it's not the way the watch was meant to be in the first place.
    • What works for me (waiting for the villagers to assemble with torches and pitchforks) is to put a liberal (in watch terms) spot of 9010 on one of the pins of the pin pallet, this seems to improve amplitude and beat error.
    • Non-magnetic is a poor description of such a hairspring. A better description would be unmagnetisable hairspring. There are metals and alloys that are attracted to magnets, but don’t become magnetised themselves. A hairspring made out such a material will be attracted to magnetised tweezers, but will not become magnetised. These hairsprings can be disrupted by being in close proximity to a magnet, but the disruption will cease the moment the magnet is moved away. These are hairsprings that could conceivably be disrupted by a magnetised hairspring stud. Best Regards, Mark
    • More than enough. Here's mine at the height I work at. I think the working distance with the included 0.5x Barlow lens is about 9".   So yes, that halves the magnification. The full story is the objective lens goes from 0.7x to 4.5x. The eyepieces are 10x, giving you the advertised magnification of 7x-45x. However the working distance is unacceptably short, so it comes with an 0.5x Barlow lens, reducing the magnification range to 3.5x-22.5x, but giving you a good working distance. What I did was buy a pair of Extreme Widefield 20x Eyepieces for when I need more magnification. You keep your high working distance, but get your 45x magnification back, at the cost of some width of field.
    • Modern ones after blue steel, invar, elinvar and nivarox , the shiny one are not supposed to become magnetised. But i have had them jump to tweezers. And i dont really understand the comment that what can be magnetised is the stud carrier and rate regulator and they can attract the hairspring ? If the hairspring is non magnetic then how can it be attracted to something else thats become magnetise, its non magnetic , that doesn't really make sense to be ?
