Bad start to 2017
clockboy
It,s was my fault I left my workshop ajar last night and found our cat asleep on the window seal this morning. Had a quick check around the bench and nothing was broken and looked ok then !!!!!! I stepped on this wheel. It is from a very cheap (wife paid £5 for it at a fair) Enfield Smiths westminster chiming clock. I have posted a couple of pics of me trying to straighten the pinion and it is almost straight but I can not see how I can rivet the wheel back on as my punches are not deep enough to fit over the length of the pinion. IMG_1046.jpgIMG_1047.jpgIMG_1053.jpg
Good idea Mark yes I have one so I will give it a try. Getting the shaft absolutely straight will be the next challenge
What fun !!!!!
Lol
Good luck - I have every confidence you will repair. :)
Here's another idea, create a larger seat for the wheel.
Make a brass collar that you secure onto the arbor that has a wheel seat centered over the old position. The seat itself will be larger in diameter than the old seat to give it strength. Secure it with locktite. Chuck up the arbor and turn a new seat and a decorative back end.
Once its made  mount the wheel in a pot chuck to open the center hole to fit the new seat diameter. Stake it on normally.
Al Takatsch
2 hours ago, oldhippy said:
Can't you drill the stake out. Its a very common movement as you know so there shouldn't be a problem.
I did think of that but I presume the stake will be hardened steel. I have found some Clock punches in various supply houses wondering if the holes are deeper to allow for the pivots.
Al Takatsch
Thats also a good idea but will I have the issue when staking the new seat i.e. the pinion is to long for my punch.
Well I suppose I could but the stake has to be domed & hardened. This is possible but a big job for a clock that cost £5. However if I can get the pivot absolutely straight I will try to solder the wheel onto the pivot.
Family commitments for the next few days but will keep you guys informed of the progress (if any!!)
7 hours ago, altaka said:
I have a lot of Rebarb steel used to strengthen concrete. 1/2 inch would do it and its soft. It will turn quick in a lathe.
Do not need to harden it because you are staking brass to brass
Al T.
Thanks family commitments stopping progress for a couple of days. Lots of options suggested with this but the priority is to get the pinion absolutely straight because other issues will surface if not.
Al T.
Don't you mean rebar steel.
Just an update with this. I just could not get the pinion perfectly straight & also I found the wheel was also out of true. I did a an experiment for future reference & soldered the wheel to the pinion which works a treat so a useful exercise.
However I have now purchased a donor movement for the replacement wheel.
What fun!!!!
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
