parts purchase on CousinsUK
Hi everyone,
I will probably need to buy some spare parts for the movement I am working on at the moment (HB cal. 313), but is doesn't feel right to buy for example single cannon pinion for £5 and then pay extra £2.5 for the delivery.
Is there a way to dodge the delivery costs or can you recommend any other UK parts seller?
Thanks.
Spare a thought for us in Australia, we generally wouldn't be able to buy anything with less than £10 postage costs, so I just trawl the website and buy a few other things I need so the postage cost gets spread across more items, that way you don't feel so bad about it.
ok, no supporters of "free shipping" :) . yes spreading the cost of the shipping in larger order is something I would usually do...
Anyway for the second part of my question: Are there more parts sellers apart from Cousins?
Thanks.
I've got a list of a number of other tool and clock part suppliers in the UK, but for watch parts I think Cousins is the go to place for the UK.
There are obviously a number of watch part suppliers in the USA, but I'm guessing you are in the UK so the postage would cost even more.
I'm only just setting up to learn to repair watches so someone who has been in the game longer than me may know of other suppliers
Then buy some more stuff and spread the cost? £2,5 is not a big deal?
Besides i pay only £1,92 to Sweden . Why do you have to pay more then me when you are from UK ?
i can put it in my order that i am doing today or tomorrow and when i get i after new year i can send it to you for  £1,5 . Saving a £1?
6 hours ago, IFELL said:
Hi everyone,
Thanks.
Well, I usually don't have too much trouble finding other parts to throw in there to make the postage feel right but if you only have one project going I would suggest using the opportunity to toss in something else that you'll need in the future- just about any tool comes to mind.
I'll add that the postage is probably about as good as it will get though.  It's an hour and a half drive from Otto Frei to my door and still can't get postage below $12 for any purchase from them.  I'd purchase direct but parking would probably end up being $12...  <_<
Your probably not going to get the part from anywhere cheaper than you can get it from cousins. Why exactly does it not feel right to have to spend a couple of pound on postage? Cousins wont get it for free. I bet you've spent more on a cup of coffee and a traybake at costa!
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
