David
sunnyside
23 hours ago, sunnyside said:
Thanks David funny my first reply should be from a member in Illinois as I have a cousin who lives in Berwyn Illinois. Could be a good omen. Thanks
Well, I happen to live in Berwyn too :)
I always say Chicago because no one knows where Berwyn is.
